Old 02-15-2015, 12:35 PM
jimib's Avatar
jimib jimib is offline
Originally Posted by helmerrock View Post
One of my winter projects is to polish the trim from my 67 GTO. I've done some trim polishing years ago using a small bench grinder. I am planning on buying a polishing motor with longer shafts than the small bench grinder. I'm undecided if I should get 8 inch or 6 inch. Is it easier to polish with a larger wheel? As most of us that have tried to polish trim, I have learned about the hazards of wheel grabbing part causing flying trim, bent parts, and sliced fingers. Is a larger wheel less hazardous? Any experience and advice appreciated.
Steve
One of my spare bedrooms is dedicated to a refurbished parts area.
As part of my ground up resto, I have shined up 75% of the stainless trim, the other 25% I’ll have to buy new. I found that no machine could do as well as “by hand” because hand work seems to get the sanding media in all the small areas a machine can’t reach. This work takes “HOURS” for a small section but it’s good beer drinking work. For most of the trim I started with a 100 grit (depending how bad) and gradually worked my way up to a 2000 grit. Lastly I would work the piece with a 3M polishing compound.
ID:	390269   Click image for larger version
ID:	390270   Click image for larger version
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
