Old 03-16-2015, 01:26 PM
Held for Ransom's Avatar
The 8997016 PH is indeed a '78-9 Formula air cleaner assy.
Old 03-16-2015, 02:04 PM
Bentwheelbob's Avatar
For me - It is always tempting to remove the foundry extra casting slag like shown on those intakes.
What say you?
Alvin - probably a good idea. I did that on my 455 HO intake, but hadn't really though about it here. It's a beautiful day here so I might just grag it outside this evening with the die grinder and clean it up some.
Originally Posted by 68ragtop View Post
I wasn't aware that POR15 was a high temp coating. I guess its not too surprising as it can withstand sandblasting to some degree. I have always used high temp silver paint under the blue for the same reason. The rust underneath the inevitable paint peel looks poor otherwise for sure.
Did you find your blue yet? I believe I have some 78 blue valve covers boxed up somewhere, I need to check..... Unfortunately my Y88 survivor cars engine has been touched up with an incorrect blue. Can't blame anyone but myself for that. When I bought the car, I detailed the engine compartment. Wish I wouldn't have now, but at the time it seemed like a no brainer to do. I also threw away the original spark plug wires & took zero pictures...... Never thought I would care years later.
68RT - the POR 15 is a high temp manifold paint they make. It's quite a bit different than their rust preventative coatings. It is very thin, and when dry has a flat to egg shell appearrance. The manifold photo shows it shortly after application while it is still wet.
On the engine paint I have pretty much defaulted to OER paint since I couldn't find anything to use as a baseline for getting something mixed. If you have an original valve cover I could borrow that would be great. I would gladly pay shipping. Alternatively, you could take it and try to get it paint matched locally. I have used the OER paint to paint several of the bolts on this car that were originally painted blue.
I would post a few pictures, but I think photobucket is on the fritz. I was planning on spraying the timing cover this evening. I'll add a picture of it later.
