Old 03-29-2015, 07:09 PM
Alvin's Avatar
Alvin Alvin is offline
Talking Martinique Blues!
Previous posts were Prompted by Spring cleaning in the garage last night after all day on yard and garden Today was Arts Festival and Dining w my beloved Mrs
Originally Posted by Bentwheelbob View Post
Thanks Alvin. Looks great. How many miles are on the clock?
IIRC when I fired her up last night around 127k on all original drivetrain and rust free bod Posted couple of pix as I believe still has factory wires, etc. Lesson I've learned is "don't" from past use rubber "conditioner" on underhood seals...
Did you get the quick connect hook up with the battery tender or are you just using the clip on connectors?
Well, I deviated from the theme bought one of those Lith-Ion boosters and used one of the handful of cheapo Harbor Freight clip on battery tenders
More pix! Can you even see the engine color?
Not much color to be seen lately due to oil seepage from valve covers, etc. used to really get bent outta shape about that kinda stuff, lately not so much. Consider myself pretty lucky to have scored this #s matching w all original purchase paperwork etc. yrs ago and realized again last night if I wanted to or had to thin the herd...this would be the one to keep...and that's saying a lot IMO as right next to this is our '79 Y84 W72 WS6 4-spd
Below are more pix that were posted on Bobs Excellent Gold Car Thread (yeah, yeah I know "what a piece of junk our Martinique is" right?)
Turns out, my washer pump wiring IS connected...into the windshiekd washer pump mounted in the fluid jug.
Our's looks like this one
With the pump installed into the bottom of the jug...
I can only post a single pic per reply from my iPad so here is the series specific to our '78 TA BTW - the wiring is blue line & white line on seperate black wiring coming off of the harness up near the top of the fender close to the plastic air intake extension
Our wiper motor WITHOUT any washer fluid pump kit below
Here's our dirty washer jug that pump is mounted below (including this for you as the grease highlights the part no's for you)
Going to provide you w several images of the pump wiring as it comes out of the harness for you now
The two-wires in the middle of the vacuum hoses are the same blue & white striped washer motor power wires...hard to get any good pic without pointer obscuring the wiring...
But my "BIG MISTAKE" was stating we have "PULSE" washer assembly seems with a bright light illumination the switch actual Sez "PUSH" so my "EXPERT Membership Card" will have to be forfeited yes?
(http://youtu.be/zANvYB93u2g)
