Not much actual room (flexibility) for the crank to be in the wrong spot and not have the roll pin, distributor gear, etc see a lot of stress.
Tom Vaught
sorry Tom, I`m not understanding the answer, could you put it in simple terms for me, yes or no haha.
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
Looks like the break point started at the drill hole, likely started by a sharp edge!
X2 on Tom's post....don't reuse the caps and get some steel caps. If that's a 2-bolt block I'd consider splayed caps. Either way sorry to see the destruction.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
I'd wait and see what the block looks like when tore apart.
I'd say the block is cracked somewhere in the main bulkhead.
![]() Tom V.
If it is a easily replaced 2 bolt block, nothing special sort of deal I would not even think about running that block again in a performance build. Could not sleep at night myself.
Sorry about your engine. But those offshore cast cranks have had issues eating thrust bearings and or failing where they should not. I have flogged PMD cranks and never hurt one of them. |
Unless it's the picture, to me it looks like the crank was cracked for a while....
Looking at the dark areas in the crack it does appear to have started cracking a while back. Definitely got some cap fretting,what are you revving it to? And why are there main studs on only number 2 and 4 mains?
You could also do with modifying the thrust bearing, file a small chamfer along the parting lines of the shells- about 0.020" will do it. Have you restricted the oil flow to the converter/cooling circuit in the TH400? You sound like you have a recurring problem with the thrust bearing and modified TH400's are notorious for causing engine thrust bearing wear. Increased trans line pressure translates into higher cooler circuit pressure which can force the converter forward,causing thrust bearing problems. |
I see what you are talking about, but I don't think they are "beach marks". I don't see a growth pattern
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
shifting at 5500, max ever revved to 6200 but usually 5800 at finish line don`t know about the studs, that`s how it was built. the Milodon windage tray was bolted to the studs both of those mods were done
http://www.gtoforum.com/f50/455-main...uestion-55713/ |
The beach marks are a true yield strength limit indicator, yet was it organic defects in the material or a machining "stress riser" that got allowed to propagate. Hmmmmm. |
You know, I never know what the heck you are talking about, but I always get the feeling you know exactly what you are talking about.
#38
LOL.
Runner Up Q16 Norwalk 2013! |
#39
