#101
Old 05-05-2015, 12:21 PM
STEELCITYFIREBIRD's Avatar
The big '75' by the dizzy in your picture is a dead giveaway from what I know.
Casting # location
http://s299.photobucket.com/user/WDC...0text.jpg.html
  #102
Old 05-05-2015, 12:35 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
I think I have a pic of that casting number. Is this it?
Here's the pic after new oil PSI gauge installed. I put the nylon line inside some vacuum hose for some added protection.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #103
Old 05-05-2015, 12:39 PM
grivera's Avatar
grivera grivera is offline
It's blurry but it appears to be 500557? Also, this pic from your album looks like it may have an additional motor-mount bolt hole on passenger side:
http://i300.photobucket.com/albums/n...2.jpg~original
Will Rivera
  #104
Old 05-05-2015, 12:56 PM
AdamIsAdam's Avatar
Between the two pics, the casting number looks like 600557. What does that tell us?
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #105
Old 05-05-2015, 01:03 PM
AdamIsAdam's Avatar
Bummer. Looks like this is not the block i thought was. What does this mean? The guy that built it said he followed a build from Jim Hands book.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #106
Old 05-05-2015, 01:04 PM
Yep.
Now you need to verify what is inside.
May be able to id stock or aftermarket crank by rear hub? I personally don't know if there is a definitive difference.
Stroke should tell the tale. You should be able to measure stroke thru spark. plug hole.
I hope someone didn't swap the short block out on you when RMS was replaced.
The two digit alpha codes were reused a bit.
  #107
Old 05-05-2015, 01:11 PM
78w72 78w72 is offline
the 6 is definitely a 5. its a 1975 500557 block. that is considered the weaker block compared to the 481988 blocks. but dont worry too much, if you aren't drag racing the car a lot or really pushing the rpms, it should be fine for normal use. 500+ hp & abuse its not an ideal block, but i wouldnt worry about it blowing up from some spirited driving or light drag use.
i would look into the internals if you can, hopefully the prev owner didnt do a switch-eroo or lie about the build.
  #108
Old 05-05-2015, 01:37 PM
AdamIsAdam's Avatar
Well, seeing as the guy I bought the car from is a "friend" of mine that I've known for a long time, I'm inclined to think he got the block info wrong, but that he didn't out and out lie about the build and get receipts to back up the lie.
As long as the motor can withstand me winding out 1st and second gears often, but not over 5,400 RPM, and maybe once a year going to the track, I'm happy.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #109
Old 05-05-2015, 01:51 PM
didnt mean to imply he intentionally lied. especially if he is considered a friend, he probably got the info wrong... or may have been provided wrong info.
you should be fine under 5500 if its not abused too bad. on the street the tires will break free before too much stress is applied on the driveline & engine. its at the track with goood traction & hard launches that the stresses can break things.
  #110
Old 05-05-2015, 02:01 PM
AdamIsAdam's Avatar
I've known him a long time and I know he can stretch the truth! That's why there were quotes around the word friend. LOL. That being said, my other buddy helped build most of the car which is why I bought it. But yes, he likely knew the block and implied it was a 1970. He probably got it cheap. That, he's the master in. But I do believe the butler inners are there.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #111
Old 05-05-2015, 04:57 PM
I'd have to know whats in it, that's my nature.
  #112
Old 05-05-2015, 05:30 PM
grivera's Avatar
based on the performance you described I'd bet the internals are what you think they are, fwiw
Will Rivera
  #113
Old 05-05-2015, 06:25 PM
AdamIsAdam's Avatar
That's sort of what I'm thinking. The bottom line is that it runs strong (when tuned right), certainly strong enough for around-town spirited driving and smokey burnouts for the kids (yes officer, it was for the kids). I want to get down the 1320 in the 12s, even 12.99, and I'd be VERY happy. I'd also like to see 400hp / 500ft lbs on the dyno at the rear wheels too.
But most importantly, is to run reliably and smoothly -- and to last a long time without exploding
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #114
Old 05-05-2015, 07:42 PM
PontGuy's Avatar
PontGuy PontGuy is offline
Lets give him the benefit of doubt- he probably just didn't know about the weaker 557 blocks, at least when he started the project. I didn't know about them until becoming active here. The receipts all look good to me and the guy that ported the heads obviously assumed they were going on a 400 with flat top pistons.
The big question I have is why the engine was built with so much compression- I get at least 10.5 and that's assuming a .020 deck height. It seems to be working OK and making great power but it must be on the razor's edge. I definitely would not put much vacuum advance on it. And figure on upgrading the cooling system to get the temps down especially on hot summer days.
Can't speak to longevity of the block since I have absolutely no experience there.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
  #115
Old 05-05-2015, 08:02 PM
FWIW, I am putting together a 400, same exact block,75 on valley... Original block that came in my 76 formula. I have an earlier 1970 block that I am saving for a long stoke motor.
At the (dirt) racetracks they use a cube checker in the limited classes, measures amount of air displaced by sweep of one piston. Not sure if anyone else does that.
Someone probably has a good reliable way to measure the stroke assembled, that may chime in. I've never done it, but I am sure it can be done.
Pulling the right plug may allow you to see in a cylinder to see if it has dished or flat top pistons in it, that might be very telling.
I'd have to know weather me and him need to have a chat.
The block isn't a reason to have a "chat", the rotating assembly would be.
Don't despair over the block, just try to verify what is inside so your not chasing your ass tuning it.
She is a nice ride, just don't hammer her too hard!
No 4g holeshots!
  #116
Old 05-05-2015, 11:47 PM
AdamIsAdam's Avatar
cooling system consists of an aluminum radiator and a two speed electric fan from a Taurus. Last summer it worked well. Tstat is 180*, so I"m told. And I run Evan's waterless coolant for some added protection.
When you say no 4,000 RPM wholeshots. You mean don't dump the clutch at 4k, right? Because I do like a long, smokey burnout once the tires are spinning already, but that shouldn't stress the engine too much since the tires are spinning.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #117
Old 05-06-2015, 12:06 AM
ta man ta man is offline
400 hp at the rear wheels will easily put you in the 12's..I wouldn't fret over the 557 block much..unless you are launching the car with full traction all the time it will last.
  #118
Old 05-06-2015, 07:54 AM
46 heads with screw in studs are of 2 varieties, one is 98 cc, the other 89 cc. And usually, they are bigger than advertised by a few CCs. Your deck height is .010, with a 17cc dish, 4.190 bore, 4.250 stroke, you are in the 9.3 - 9.8 range. Which makes more sense.
The info on the head flow sheet is bogus, the guy just plugged something in to do initial calculations, it's the flow data that is important.
  #119
Old 05-06-2015, 08:20 AM
AdamIsAdam's Avatar
ohhhhhhhhhhhh!!!!!!!!!!!! That makes much more sense!!! And makes me feel better that it's not such a high CR. THANKS!!!
Just curious, how come you can't calculate the exact CR? Are you missing some piece of info?
Also, these heads were converted to screw in. Not sure if that helps you any.
Is there anything else you can tell me from the paperwork that I either had wrong or didn't know? This is great stuff. It's like tracing a family tree all the way back
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #120
Old 05-06-2015, 08:41 AM
If they originally were non-screw in studs, they are in the 96-98cc advertised range, so it would be closer to 9.3 SCR. And no, there's no other info on the docs that you really need to know, all standard stuff.
