Current Pontiacs -1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
Limited options as if was ordered to run the strip
meh;
IMHO, if it were meant to run the strip on a budget, the Formula was the winner.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
The guy definitely gets this weeks honesty award. The prison part is priceless.
Probably not the smartest thing to tell people when your selling a car.
....this latest one is defiantly a Bird of a different feather.....no doubt there has been some $$$ spent in trying to save it....poor thing.....
Has '80/'81 gauges.. He would've been better off leaving the aftermarket gauges in it IMO. Looks like its loaded with bondo too.....check out the R/R 1/4 around the marker light..
He's gonna lose his a$$ on this one...
Nope. Close though. Wrong tires
10 bolt posi? 8)
That thing actually looked pretty cool in orange. The tweed interior screams late 80's early 90's build. The paint on the wheel wells was an interesting choice.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
At least the guy admits he needs to sell it to help make a better life for him. But man that car is messed up! The office furniture when it was orange, was yuck!
69 Judge RAIII 4SP 2ND OWNER 63 Catalina 421HO 4sp 66 GTO Conv 4sp 73 Trans Am 455 4sp http://www.sdperformance.com/ Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds. |
A pumpkin with a blueberry interior, Wow
Well, I had a deal to buy this car, but upon inspection pulled back. All the mechanical parts checked out correct PN and date, but the master cylinder, even the starter. However, the left fender and hood were late model, and the shaker had no markings. I think the car got hit on the left and the fender, hood, and shaker had to be replaced. A beautiful car that someone will be very happy with, but not me. Here is the link and inspection report.
http://www.ebay.com/itm/Pontiac-Tran...m=221776673802 All 4 wheels are JW dated 1/26. 70 22387 NOR 719439 201 26 26 02C WS4 Engine: R- Head #12 dated A280 L- Heads #12 dated A280 Intake -9799068 dated A220 Carb: 7040270 0080 WA Alt.: 1100902 A270 Starter: part number ends in 436 9M22 Rearend: COX 12 bolt Left fender and hood are not correct, Hood has four rectangular holes in front inner structure. Date under hood is A232 Brake booster is painted instead of plated. Small paint chip on left rear trunk spoiler end. scratch on right rear corner of back bumper. Left fender alignment to door is not right, too wide of gap toward the bottom. front bumper alignment to fenders on ends could be better. minor paint touch up on center of front nose. saw pic of vin. number of block and it matches. Small coolant leak at timing cover where it meets the block, may seal with stop leak or need fixed. Leak found at rearend chunk, not sure if it is rear gasket or what. The car is a nice looking car with lots of correct parts. It would need some work to be concourse show. Paint looks good overall. Places noted in this report detail any problems with finish. I could not see AMP on the shaker, could have been covered up or something. Gauges worked when driven. Rear Roll Pan bottom edge was not painted and can be seen from the ground. |
That's a good inspection report!
Few questions... How can you see starter numbers without removing it? Trans has matching vin too? Rear usually has date too? Like to check date on block, engine code, and look at other things just in case it's been tampered. Sounds like it checked out good, and you're looking for a concourse? What are you interested in mostly?
Mike/Illinois |
Mike,
We know that Bob's going to take it all apart anyways, but for that much money he didn't want to take it that far apart. Ya know? ![]() Chris
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#38
Trans - couldn't see trans due to exhaust and placement in tunnel Axle - could only verify COX code and that it was a 12 bolt. Given everything else it seems a reasonable bet to assume date code was good. Block - VIN was verified as was YZ code. Couldn't see date code even with mirror, but given VIN match, and date code match on heads, intake, right ex manifold, alt, and distributor, that too seemed a safe bet Probably not a concourse, but for what you would have been in on this money wise after replacing hood, shaker, fender top, stripes, MC, fuel line, fixing spoiler chip, re painting rally II's and buying polys, et cetera, you would have been into it for concourse money with no room left. Pay transport, taxes, licensing and you are upside down. It's a really nice car, but what really bothered me was that within 30 seconds of opening the hood any reasonably bright Fbody guy was going to be asking about the hood and fender. Quote:
I need to get back on the Gold Car, but me, MPD and the W72 need to take a little road trip before that can happen, and time is in short supply during the week for me right now. |
#39
I don't usually shark tank cars, but a couple things just made me chuckle here:
http://www.ebay.com/itm/Pontiac-Fire...m=221780189483 1) The vinyl case placed in all dash shots over we all know: "The Hole". Whoops, I didn't mean to leave my sunglasses over that hole, sorry about that! 2) It looks like 4 or 5 cans of splatter (maybe) paint exploded in the trunk. Kinda creepy.
72 Bird |
#40
Wrong honeycomb caps Terrible CD player in dash Wrong spoiler ends
71 Starlight Black Formula 455 L75 88 Flame Red Metallic GTA Notchback |
