Old 06-07-2015, 02:53 PM
Pontiac Derek Pontiac Derek is offline
The RPM is much better than the performer or P4B Q jet flange, Especially ported, you will gain 10hp up top but lose 10ft lbs down low with a 1" open spacer, a 1" open spacer will net you your best et's and you will be right there with a T2 that is untill the T2 is fully ported with a 1" open spacer fwiw
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
Old 06-07-2015, 03:07 PM
ta man ta man is offline
Thanks I gasket matched my rpm intake to my heads,blended it back about 2 inches.I don't think this intake will make more peak power than my Torker 2,but will it make up for the peak horsepower loss with the higher torque numbers down in the rpm range?My torker 2 ran its best with a one inch tapered 4 hole Wilson spacer,you could actually feel the torque difference and throttle response over a one inch spacer.
Old 06-07-2015, 04:03 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good luck with your testing it will be interesting to see your results. About 10 years ago I tested the Torker II against the RPM in my 80 Trans Am with a pump gas 462, ported iron heads, 2800 stall and 3.42 gears. My results were;
Performer RPM 11.42 @ 118.65 with 1.673
Torker II. 11.51 @ 118.31 with 1.685
I remember analyzing the time slips and thinking the T2 was a bit slower between the 60 ft and the 330 ft mark.
I had to go up two jet size when I installed the T2 and use slightly larger pump nozzles.
Keep up the good work!
Go fast, see Elvis!
Old 06-08-2015, 03:59 AM
That's what I'm thinking will happen....thanks for the heads up on carb setup...I've been thinking of less pump shot with the rpm..I've had a couple seasons dialing in the 950hp on the torker 2 ,it leaves pretty good.May take a bit to really dial in the rpm for a fair fight.
Old 06-08-2015, 09:49 AM
I have, and Dave at SD has a interesting porting program for the T2 intake, normally porting=making things bigger which slows air down, except ive found by porting the T2, plenum and runners it actually picks up air speed and torque throughout the rpm range, the RPM is Hard to beat in a streetable setup but it can and has been done, the Tapered 4 hole spacers do better on the street/track than the open spacer does until the cubes get up over 470 it seems to start needing a bit more plenum volume, depending on having the correct combo, good job and good luck testing! I know one thing you wont gain much going to a lower gear set! Got to love these Pontiacs! Tell a chevy guy you run 3.08 gears and then your et lol thats a funny look!
Old 07-09-2015, 12:25 PM
All this testing may come to an end soon,I've decided to make the best of my engine combo.The 3.08's are great on the highway...but I really want now is to push into the 10's...and really give SD's head cam combo what it deserves..plus I want to lay a spanking on my buddy with his 555 BBC on 110 octane !
Old 07-09-2015, 12:28 PM
leeklm's Avatar
leeklm leeklm is offline
It was bound to happen
Old 07-09-2015, 04:24 PM
PAUL K's Avatar
How fast is your buddies 555 BBC?
Go fast, see Elvis!
Old 07-11-2015, 11:18 PM
I'm sticking with the 3.08's,I already have my buddy beat as far as street cars go,I have 93 less cubic inches,I run pump gas,I drive to the track and run almost as fast.I took the car out for a good drive yesterday..and made my mind up.I have a few ideas how to drop a bit of et.
