Old 06-17-2015, 09:48 PM
77 TRASHCAN's Avatar
Originally Posted by Ben M. View Post
I'm actually getting real world here on this... I've got a 455 that I think needs a valve job at minimum and most likely has a bad lifter (or cam lobe) in a HEAVY wagon, 3.08 rear end, 100% street car that will never see the track and I want to run 87 octane, my AC, and power brakes. Rebuilding the original 4X-1H heads and putting another 066 cam in it seems like a waste of money and leaving potential power on the table. What do experts recommend here?
My logic for 87 octane isn't related to cost - more when you're traveling on the road 500 miles from home a bad tank of gas can really mess up your day.
I don't have a clue what size the chambers are on your 4X heads, But the 068 would be a minimalist cam choice to me for a 455.
You're not looking for the absolute power numbers, would be a great driver, not give up any low end rpm drive ability or MPG over a 066 cam, may make both better! As communicated here quite often, the awesome 068 cam can be used w/ stock springs.
Shut it off
Shut it off
Old 06-17-2015, 09:52 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Advertised as 114cc for an 8.2:1 compression ratio! Not called "soup bowls" for nothing ;-) I've done the 6X-8 + 455 build before and it was impressive. The 068 does seem like a good choice, I just hear so much flak from people on how it's "old technology." I've got a clone of it in an 8.5:1 400 with 3.55 gears and it's plenty fun to drive.
Old 06-18-2015, 06:02 PM
wovenweb's Avatar
wovenweb wovenweb is offline
Old technology does not = bad technology. Only bad technology = bad technology.
Old 06-18-2015, 06:17 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Truth
Go fast, see Elvis!
