Old 06-27-2015, 10:59 AM
462-6spd 462-6spd is offline
I'm running the Edelbrock E-Street EFI throttle body on their Pontiac Performer RPM manifold, just used a spread bore to square bore adapter plate. No issues.
Thanks, Gary
Old 06-27-2015, 01:39 PM
Thanks, Gary
The thin plate version adapter will work on performer or rpm intake. However, on a stock intake you need a 4 hole square bore to spread bore adapter. Typically an inch or bit less tall.
IF the throttle body has provision for small or large bolt pattern, a thin adapter(@1/8" like the AFB/Holley adapter for Performer or RPM that Edelbrock sells) on a stock intake, would require making clearance and some blending at the throttle bores of the intake.
Old 06-27-2015, 07:29 PM
Squidward's Avatar
I was reading about Fitech Go EFI last night, and theirs is supposed to do spread or squarebore.
