Agree! (Thanks for the jump in moment)
Throw CV's, tigers, high ports,, warp6, raV on same motor, same turbos, and still achieve same power. Variances in boost at same power or some difference in power at a fixed boost psi is what you would see ! Seems foolish to think that because no one else has tried, that it can't be done Mr Paul's comment IMPLYING that NA E-heads have done same or better as Mr Fulton's cv1 combo is questionable if not totally misleading. I know of NO OTHER NA combo making 1100 HP AT SAME COMPRESSION . (Let alone not cammed for NA application) All NA combos I'm aware of exceeding 1100 hp using other heads run well over 14:1 compression and are cammed for NA at higher rpm as well. Mr Paul, have you got examples to show I'm wrong? BTW what's your highest HP Pontiac NA build from YOUR shop? |
I hope after all this that both partys show up and get past this. Im sure Jack will be there and will have the best setup possible with the testing he has done to that point. I drove one of my guys cars a few weeks ago that runs 6.20s in the 1/8th mile. I was in the low 6.40s. He could have sat in it and run .2 faster than me the next pass. Track time is everything.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Do you specialize in port development or are you just another machinist with a die grinder porting heads and intakes? I'm honest enough to say even I can make improvements with a die grinder and sand rolls but NO WAY am I a head porter nor am I claiming I could out do your work. 1100 HP NA Pontiac as a nitrous build(with the n2o off) compared against an NA Pontiac build with same ci or larger with over 3 points more compression is splitting hairs??? Really??? Cam timing events totally unfavorable to optimum NA requirements, manifolding, headers etc.. Really??? Just maybe you ought to find out who else uses the dyno Dick uses. Maybe you want to find out who witnessed results. Maybe find out what Dicks track reults were with his E-heads compared to numbers from same dyno. Others results from same dyno. Its OK for you to tell us a dyno number, but somehow anything from the CV camp is a lie? Dont get me wrong, not diminishing anyones Pontiac 1100+ hp NA build(not many regardless of head choice and they benefit all of us eventually), nor am I out to diminish your customers results. I do however look at what an entire build is and judge it accordingly. They are all the sum of what they are. To suggest nearly 4 points compression and same or greater cubes at higher rpm is "splitting hairs" is about as misleading as it gets. Its as if you are assuming the average reader in this forum isnt smart enough to see the difference or know that a power adder motor is a completely different build than an NA combo. |
... just a nice pic update ...
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
I wonder how many here realize or are aware you could find 30 or more HP if you were willing to go after it.. (no small task) 2nd to your comment. What assumed load of N2O would you eventually plan to be adding to your base of 1130? Do either of us know if the DF LJ race is only a test/tune for future plans??? I don't have that info. I do suspect Dick and Bill haven't built a grenade and are leaving plenty of reserve for the future. I'll stand by my previous comment. |
Both engines made GOOD power. One side saying billet heads make the other "max effort unlimited budget" while that same side has multiple "experts" contributing expertise and multiple dyno sessions sounds a little silly to me. And Jack should buy a gearset just saying.
I already assumed he's made a gearset change, with the assurance he will be there.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
To me "sum of parts" is just that and agree price doesnt guarantee anything. "Sum of the build" has nothing to do with dollars spent. The pieces used(what you start with) + the knowledge applied(what you did with the pieces) + results obtained make up the "sum of the build" . Not a mathmatical equation, it can be a judgemental evaluation or a direct comparison and sometimes both. (preferably apples to apples or all factors considered when it cant be) Sorry for the confusion. |
| Closed Thread |
