Fulton has Nitrous 3 stages 2) The Ford had a Dry Sump System Fulton has a Dry Sump System 3) The Ford was running a Canted Valve "Old School" Yates head Fulton is running a canted valve head. 4) The Ford was running a 10.5 W tire Fulton probably has something better years later. 5) The Ford as was said was running basically a small engine (with rpm) Fulton is running a much larger engine within 500 rpm of the Ford engine's rpm 6) Compression ratio is similar if you believe the posts on the board. So how do these specs resemble a John Force plastic bodied vehicle with a Mopar engine? Tom V.
1000s of max effort Fords out there, only a dozen or so all out Pontiacs "old school" heads with 50 years of development compared to street heads worked over a real comparison would be an FE Ford vs. Pontiac...not even close
1989 Automotive Hall of Fame Inductee |
| Closed Thread |
