Old 07-20-2015, 11:39 AM
conceptfab conceptfab is offline
Default My turbo 1974 Ventura
Its got a stock 389, 6X heads, summit 2801 cam, TV7101 turbo, tial wastegate and bov, msd digital programmable 6al-2, air/water intercooler, and all the tubing was cut and TIG welded by me including the reservoir, fan shroud, intercooler, dual 3.5" stainless exhaust, stainless downpipe, etc. And here is a short 3rd gear pull at 9 lbs https://www.youtube.com/watch?v=SQHdZFsmLXg
ID:	403308   Click image for larger version
Old 07-20-2015, 03:48 PM
Macho78's Avatar
Macho78 Macho78 is offline
What compression and fuel are you running?
78 Macho T/A #123 [email protected] on motor [email protected] w/190 shot.
Old 07-20-2015, 04:54 PM
the compression calculator with a factory 389 bottom end and the 6X heads puts it at 7.6:1 compression and I run 91 and 100 octane mix till I sort out the timing and general tune
Old 07-20-2015, 11:35 PM
Nice work!
Old 07-21-2015, 01:09 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
So do you have a perma-grin on your face?
Congrats on joining the turbo Poncho club
Old 07-21-2015, 05:30 AM
Squidward's Avatar
Hey, I see that AZ plate! Are you in the Valley, or elsewhere?
Mad respect for doing all your work! I hope to join the club some day.
Old 07-21-2015, 09:21 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Awesome, keep an eye on the a/f gauge till you work it out. I started at 6 psi. You will get different opinions but I like it safe . 11.7 is my roof past that I lift just in case!
Old 07-21-2015, 10:58 AM
68azbird 68azbird is offline
He down below Tucson
Old 07-21-2015, 12:58 PM
Thanks for the compliments guys! I am an hour south of Tucson. Where are you other guys located in az? I want to get some paint and body done and go to some shows and hopefully we can all represent the boosted Pontiac scene together
Old 07-21-2015, 01:21 PM
Macho78's Avatar
Wow, stock bottom end (cast pistons and stock rods) at 9psi. What kind of power do you think it is making?
I'm in Glendale.
Old 07-21-2015, 01:33 PM
Ive run as fast as 11.9 at 114 in this car with the e heads and roller setup and have driven lots of cars but its never had this top end. This is hard to call since I have done all the handling stuff like tubular upper and lower a arms, qa1 coilovers with 550# springs and 1" solid sway bar and poly ends, and reloated corvette shocks in the rear. Its a really tight ride and I know it would eat up a new ZL1 Camaro as I just drove one of those recently but I would equate it to a heads/cam C6 Z06. This engine revs quick! Its not uncommon to hit the recall on the tach and see 6300 rpm! But once the boost hits in second it just winds up so fast its almost a race to balance being pushed in the seat, checking for cars up ahead, and jumping off the throttle. Id have to say if I can hook, this car it should be good for low 11s. Id really like to turn it up to 12 lbs and leave it there. I also need to program in the rev limiter to 5800 rpm!
Old 07-21-2015, 02:26 PM
GTOGEORGE's Avatar
My original 74 GTO wieght around 3,400 with a 3.42 gear and a turbo 400 trans with a stock converter the engine was a 455 with a crane fireball cam the heads were stock and a stock. It had a small b & m 174 street charger, the car ran the best of 10.89, I never ran more then 9 lbs of boost!
GTO George
Old 07-21-2015, 02:31 PM
those are some good numbers gto George. What was your elevation?
Old 07-21-2015, 04:26 PM
bankbook's Avatar
bankbook bankbook is offline
Looks good!
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 07-21-2015, 04:52 PM
southside39 southside39 is offline
What did you do for exhaust? Custom headers or manifolds flipped around?
Old 07-21-2015, 04:55 PM
GTOGEORGE's Avatar
About 2,000 feet below yours.
GTO George
Old 07-21-2015, 05:15 PM
Its about 4600 feet above sea level here and Tucson usually has an awful DA. Its one of the slowest tracks out there but when I get there ill be sure to post some numbers. And its got factory manifolds installed the same way as they came from the factory. I did all the piping from there up to the turbo and 3.5" downpipe to dual 3.5" exhaust. All the hot side was done after the manifolds in stainless steel and the cold side is all aluminum TIG welded together
Old 07-21-2015, 05:27 PM
Macho78's Avatar
Did you run the hot side from the manifolds to the front, under the control arms? Any clearance issues if you did?
Old 07-21-2015, 05:36 PM
Curious George's Avatar
Curious George Curious George is offline
Cool, welcome to the club!
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 07-21-2015, 05:53 PM
thanks George and macho it comes up where the oil filter goes and goes down in the same area. That's why my down pipe is only 3.5" I made an oil filter relocation kit and the filter and housing are now right in front of the passenger front tire
