#2521
Old 08-08-2015, 10:09 AM
bird72's Avatar
bird72 bird72 is offline
If any of the HO gurus can weigh in, appreciated. What would be average fair retail you personally would pay for top end parts for 71: heads, intake, crossover. Heads is loaded question I know, range from fresh done to cores no parts, so say good shape cores with all parts for example. Trying to figure market on what is middle range deal to high retail (such as some ebay buy it now ads). Thanks.
72 Bird
  #2522
Old 08-08-2015, 10:58 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
I'll try...
The 191 heads:
I personally wouldn't buy a set of bare heads off ebay or anywhere else unless it was from someone I knew well. I am very suspect of bare heads. If you took time to tear them down, why didn't you build them back to ready. If you have a fresh complete set that are ready to bolt on with premium valves, springs, etc.... those were bringing $1500 - $2000 depending on how good of shape they are in. Most people who sell fresh heads can and will provide receipts from the machine shop work attesting to the parts used and show proof that the heads were magnafluxed and pressure tested. Nobody I know buys bare heads from an unknown source, least not me.
I would get them checked out at a good speed shop and assembled with premium parts before I would try to sell them. Most shops will not rebuild a bad set of cores. If they are rebuildable, you will sell them more easily, and make more money if you do.
The Intake & crossover:
If there is no damage or signs of repairs and all the bolt threads are in good shape or have been repaired with heli-coils, I'm guessing about $800-$1,000 for the matching pair.
$2300-$3000 on average if everything is pristine with no hidden surprises. Nasty or Rusty wont sell for much.
Hope this is what you wanted to hear.
Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #2523
Old 08-09-2015, 10:30 AM
bird72's Avatar
Yes thanks it is. Good advice on heads. I'll follow. Thank You! If anyone has a 71 top and don't need PM.............
72 Bird
  #2524
Old 08-09-2015, 01:10 PM
Alvin's Avatar
Alvin Alvin is offline
You may want to contact Talladega Alabama vendor for what you seek http://forums.maxperformanceinc.com/...d.php?t=778084
And/or many other in Parts For Sale sections here on PY... Shop around and you're sure to score what you seek using "Patience is a virtue" to guide you.
  #2525
Old 08-09-2015, 05:04 PM
Judge273's Avatar
Judge273 Judge273 is offline
I noticed after all these years my 71 HO dipstick non ac is different from my 72.
Anyone know if one is right for each year or none?
Mike/Illinois
  #2526
Old 08-09-2015, 05:46 PM
I'd say the 'Use SE oil' would be correct.
The SE oil designation started in 1972 Model year.
(1971 didn't have that designation)
EDIT: The SE stick is for 1972, the other is for older engine.
Thought you were asking about a 72 engine.
  #2527
Old 08-09-2015, 05:52 PM
Sport71's Avatar
Sport71 Sport71 is offline
Hey Mike,
I've got the one on the bottom. Mine is also '71 HO non-A/C ...
Vince
1971 GTO 455 H.O. Ram Air
Nordic Silver - Black
  #2528
Old 08-09-2015, 07:06 PM
Judge273's Avatar
The top one is from my 71 and bottom in my 72.
Thanks for the responses and thoughts.
Don't think it's a A body vs F body as Vince has the 71 A body with the bottom one?
Mike/Illinois
  #2529
Old 08-09-2015, 08:35 PM
No difference in the '71 non AC dipsticks between d port and roundport, the differences was when the roundport '71 had factory AC, then there was a different dipstick for A body and for F body.
  #2530
Old 08-09-2015, 10:40 PM
1971455HO's Avatar
Thanks for posting this up Mike.
Thanks "ol Pinion head for the non-AC clarification. If you don't mind sir, what was the difference in the '71 F body HO w/AC dipstick versus the '71 A body HO w/AC?
Ol' man Smith
Son video'd this...
  #2531
Old 08-10-2015, 01:25 AM
Alvin's Avatar
My WAG would be the AC dipstick is longer to curve around and under the compressor and mounts.
  #2532
Old 08-10-2015, 02:10 AM
hiyabradHO hiyabradHO is offline
Where can I find a correct 1971 TA dipstick for a AC car?
  #2533
Old 08-10-2015, 02:28 AM
The guy with the white car has no HO decal on his shaker !!!! I wonder if you know why that was??
  #2534
Old 08-10-2015, 03:00 PM
2manyT/A'S's Avatar
At this point....I believe it's a "no HO" didn't get under the hood YET......and owner indicated that it was a 1970 455 block.....
The lack of""hodecals" on the shaker prolly indicates a D port engine
Eye Candy......garage band?
Go full screen & turn it UP!
  #2535
Old 08-10-2015, 03:07 PM
Judge273's Avatar
None of the many HO curators have a dipstick for non AC to post? 71 or 72.
Mike/Illinois
  #2536
Old 08-10-2015, 05:58 PM
1971455HO's Avatar
My Bad, I misunderstood. I got it now. I thought he meant there was a difference between the A body & F body HO AC dipsticks.
Please correct me if I am wrong:
"I'm pretty sure, the 455HO AC dipstick was different from the Standard 455 AC dipstick and it bolted up to a different location on the upper support bracket.
I did not know about the non-AC dipsticks being the same or interchangeable on HO & standard engines. That's good news for guys with non AC cars.
The original HO with air conditioning dipsticks are scarce, and the repro upper tube that fastens to the upper AC support bracket that I have seen, are not even close. I have my original upper AC type tube, but can't use it because the factory brazed on tab came off and damned my butt...I've lost it. I'm having to run something I found on cheat-Bay. The original upper tube has a flat side that orientates toward the block so it clears. It's a tight fit for the round port AC type dipstick. Anybody have an upper tube they can post up? I would like to duplicate the tab that came off of mine.
Ol' man Smith
Son video'd this...
  #2537
Old 08-10-2015, 06:22 PM
Alvin's Avatar
Talking
But, they're both AC cars. Both have the same engine, exhaust, compressor, etc?
  #2538
Old 08-10-2015, 06:44 PM
1971455HO's Avatar
I have both kinds here...If I could just learn how to post up pics. The last time I did any, They eat up the whole Forum page, as in huge. I'm not good with computers.
Ol' man Smith
Son video'd this...
  #2539
Old 08-10-2015, 07:14 PM
I suck at uploading pics as well. I'm currently in the middle of taking thousands of pictures with my old Minolta digital camera. Most likely going to have to buy a new desktop to upload them, such is life
  #2540
Old 08-10-2015, 07:43 PM
an original '71 A-body 455 HO AC dipstick is aprox 3/4" longer than '71 F-body 455 HO AC dipstick. I have an original '71 A-body HO version, have never owned the '71 HO F-body AC version, have only had a non AC '71 T/A project.
For '72, the upper oil indicator tube for 455 HO cars was slightly different than the '71 HO version. The '72 HO upper tube is the same as the one used on the '73 & 74 SD cars that had AC. This style, '72-74 roundport app upper tube was reproduced about 15 years ago. avail from PY...assume Ames.
The dipstick used with the AC application '72 HO and SD cars with AC is the same as used on many years of D-port AC cars.
