Old 08-09-2015, 05:04 PM
Judge273's Avatar
Judge273 Judge273 is offline
I noticed after all these years my 71 HO dipstick non ac is different from my 72.
Anyone know if one is right for each year or none?
Mike/Illinois
Old 08-09-2015, 05:46 PM
I'd say the 'Use SE oil' would be correct.
The SE oil designation started in 1972 Model year.
(1971 didn't have that designation)
EDIT: The SE stick is for 1972, the other is for older engine.
Thought you were asking about a 72 engine.
Old 08-09-2015, 05:52 PM
Sport71's Avatar
Sport71 Sport71 is offline
Hey Mike,
I've got the one on the bottom. Mine is also '71 HO non-A/C ...
Vince
1971 GTO 455 H.O. Ram Air
Nordic Silver - Black
Old 08-09-2015, 07:06 PM
Judge273's Avatar
The top one is from my 71 and bottom in my 72.
Thanks for the responses and thoughts.
Don't think it's a A body vs F body as Vince has the 71 A body with the bottom one?
Mike/Illinois
Old 08-09-2015, 08:35 PM
No difference in the '71 non AC dipsticks between d port and roundport, the differences was when the roundport '71 had factory AC, then there was a different dipstick for A body and for F body.
Old 08-09-2015, 10:40 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Thanks for posting this up Mike.
Thanks "ol Pinion head for the non-AC clarification. If you don't mind sir, what was the difference in the '71 F body HO w/AC dipstick versus the '71 A body HO w/AC?
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 08-10-2015, 01:25 AM
Alvin's Avatar
Alvin Alvin is offline
My WAG would be the AC dipstick is longer to curve around and under the compressor and mounts.
Old 08-10-2015, 07:43 PM
an original '71 A-body 455 HO AC dipstick is aprox 3/4" longer than '71 F-body 455 HO AC dipstick. I have an original '71 A-body HO version, have never owned the '71 HO F-body AC version, have only had a non AC '71 T/A project.
For '72, the upper oil indicator tube for 455 HO cars was slightly different than the '71 HO version. The '72 HO upper tube is the same as the one used on the '73 & 74 SD cars that had AC. This style, '72-74 roundport app upper tube was reproduced about 15 years ago. avail from PY...assume Ames.
The dipstick used with the AC application '72 HO and SD cars with AC is the same as used on many years of D-port AC cars.
