#2541
Old 08-10-2015, 08:00 PM
Brewster's Avatar
Brewster Brewster is offline
Got the motor in now I need to throw the rest together to make the nats. Hopefully the paint guy will come through>>?
  #2542
Old 08-10-2015, 08:58 PM
Bentwheelbob's Avatar
Man, that looks great. You've got a ton of work in front of you and only 17 days to do it. Good luck getting it done. I look forward to seeing you.
  #2543
Old 08-10-2015, 09:27 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=753371
Here is a discussion from earlier. I would bet the SE would be the later 'stick. Any have ones marked 6 QTS?
The part numbers for the A/C oil rod indicators in '71 were 483765 for F-body and '766 for A-body, '72 was 9793341. Non-A/C used 9793342 for both years.
  #2544
Old 08-10-2015, 10:16 PM
weranc55's Avatar
weranc55 weranc55 is offline
Lol . I thought was in trouble and have been doubting if I'm gonna get my stuff done. You just made me feel a lot better
  #2545
Old 08-11-2015, 06:45 AM
Brewster's Avatar
I know right, Well all we can do is try an hope things turn out okay. Have to remember its suppose to be fun kinda like that game of golf
  #2546
Old 08-11-2015, 09:32 AM
weranc55's Avatar
Keep plugging away. Even if you don't get the car done for the nats at least it will be closer to being together than it is today. I would come and also give you a hand but my plate is full. One piece of advise I usually put my starter and manifolds on before I put the motor in. Since your core support is off I would mount my rad and fan shroud to it and mount it as one piece. Good luck
  #2547
Old 08-11-2015, 10:15 AM
Judge273's Avatar
Judge273 Judge273 is offline
We will get that motor running this weekend....cue the Steppenwolf
Mike/Illinois
  #2548
Old 08-11-2015, 01:12 PM
Brewster's Avatar
The exhaust and starter will be on before I bolt in the motor. Just have it in place attached to the trans for now. Thanks Chuck and see if you can make it theres plenty of rooms available and beer
  #2549
Old 08-11-2015, 04:22 PM
Norwood's Avatar
Norwood Norwood is offline
The core support is off?????didnt you tell me today you didn't take it off?
  #2550
Old 08-12-2015, 10:38 AM
weranc55's Avatar
The next thing that's coming off is the subframe. I've done this so many times it makes me sick. My one blue car has been of the road for 9 years now.
  #2551
Old 08-18-2015, 11:02 AM
bird72's Avatar
bird72 bird72 is offline
Has anyone here done a roller HO??? Info on results if so..... Would you HO guru's expect what from that build? I am hearing on a performance cam you can bet better idle with roller over old style. Along with HP better. Imaginary balanced HO with good forged pistons, stock 71 heads / intake, RA exhaust.... what bang for buck might one expect HP wise going roller over stock? HP potential gain? I know grind determines.... this for street decent mannered driving engine to maximize HP in 0-5500 band. Want as big power in street band as possible and still drive decently idle..... run AC / auto tranny 3.23....... winter build planning.... THX
72 Bird
  #2552
Old 08-18-2015, 11:33 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Here's our experience...
http://www.hotrod.com/how-to/engine/...fix-up-part-1/
http://www.hotrod.com/how-to/engine/...fix-up-part-2/
http://www.hotrod.com/how-to/engine/...fix-up-part-3/
  #2553
Old 08-18-2015, 12:19 PM
bird72's Avatar
Holy Smokes Rocky, that is incredible info. You answered everything definitively in one shot. That is close in many ways to build I envision. Should I seek bigger quadrajet with a 750 on hand now? The numbers you achieved are what I hoped. Plus 500tq plus 400hp..... that makes for a fun driver and if it is streetable and decently mannered to boot that is very very sweet. I'll print out to give to builder, thanks so much. Confirms all I have been advised locally by smart folk in engine biz.... these are not cheap builds it is the proverbial cliff jump... I will want everything done right and thought out. You saved the day sir!
72 Bird
  #2554
Old 08-18-2015, 06:14 PM
SD455DJ SD455DJ is offline
Bird72,
Dan built the numbers matching 455 HO for Darrell Davidson's '71 Judge tha basically followed the Pure Stock Drag rules with the exception of a roller cam with roller rockers, so Darrell doesn't have to worry about ZDDP heavy oils. The heads, intake / exhaust manifolds, and 800 cfm Q-jet (7041273) are all factory, no gasket matching or clean-up, 9.5:1 compression with forged rods and pistons, factory crank and dynoed at 475 hp and 575 lbft torque through the manifolds after a little tweaking.
Darrell or Dan can comment further if I got some of the details wrong. It did surprise us with the big numbers. I can't recall the specs on the cam, but, I believe they were around 230/240 @ 0.050" and 0.530" lift ground on a 112 LSA.
This motor made a clean 50 hp and 50 lbft torque more than the pure stock 455 HO's with the 068 HFT cam.
Dennis
  #2555
Old 08-18-2015, 06:16 PM
71HOT/A 71HOT/A is offline
I've had mine back in the car for a few months and could not be happier with how it performs. All forged lower like Rocky's but small domes to bring the compression to 9.8 to 1. The cam is a solid roller, 4/7 swap .582 lift 243/[email protected] 112 lsa with H.S. 1.5 rockers. The heads were ported previously so we left the ports alone and concentrated on the most accurate valve job possible. I couldn't say how much hp or tq but flooring it in third at 60 mph will spin the tires.
  #2556
Old 08-18-2015, 06:20 PM
I forgot to mention this is with the 2.5 outlet manifolds and pypes crossflow exhaust. It is still very street and actually gets a little better mpg.
  #2557
Old 08-24-2015, 10:31 PM
2manyT/A'S's Avatar
Default Back again......
http://seattle.craigslist.org/see/cto/5178330124.html
Eye Candy......garage band?
Go full screen & turn it UP!
  #2558
Old 08-24-2015, 11:22 PM
Alvin's Avatar
Alvin Alvin is offline
Wink
Originally Posted by 2manyT/A'S View Post
IIRC - same pix as last time?
  #2559
Old 08-30-2015, 09:27 PM
165th's Avatar
165th 165th is offline
Brewster, here's a pic that may be helpful. Note the cylinder numbers are stamped on each plug wire.
Name:	distributor cap wiring 2.jpg
  #2560
Old 08-30-2015, 11:32 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
We have built 2 numbers matching 72 HOs recently. These were machined and prepared to OEM specs except for valve seat angles, hyd flat tappet cam timing (230/240) and 1.65:1 stamped rocker ratio. 435-462 hp and 555 TA. No port work or gasket match needed. Both very nicely restored. The difference we concluded was in the carb...one was that much better. Stock jetting in both. The torque and power are in there with a few smart parts choices. Good luck.
