WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Transmission Tech
93-02 Transmission Tech Automatic or Manual trans tech
Old 06-17-2015, 12:47 PM
sdx455's Avatar
sdx455 sdx455 is offline
Default Keisler TKO 600
I just read something about problem with missing 3rd gear , anybody have info on the shift finger upgrade and rod ?
73 GTO 455 TKO 600 3.90
Old 08-11-2015, 12:05 PM
notime's Avatar
notime notime is offline
My son is having a problem keeping his in 4th also. Would like to know too.
WWW.SUPERCARCREATIONS.COM
Old 08-11-2015, 12:28 PM
tom s tom s is offline
The problem as I have found if from OLD muncies shifters!When go go for 3rd from 2nd you need to just go straight but the tendency is to push too hard toward 3rd and you sometimes hit the "taint"!Taint 3rd and taint 5th.I have thought many times about trying to come up with a 5th-rev lock out.Tom
Old 08-11-2015, 01:30 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Yup. Once I "trained" myself to calmly go for 3rd I haven't had a problem going straight up from 2nd.
Popping out of gear is a whole separate issue, that I've never had.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 08-11-2015, 03:26 PM
I have owned 3 Tremics and have never had a pop out of gear issue.Tom
Old 10-05-2015, 02:58 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Wink
The unloaded gate is the 3-4 gate. Just push forward and it will naturally go into the 3-4 gate. I learned this while testing Vipers at work. You almost don't want to think side ways....just forward.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 10-06-2015, 12:21 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Over a certain rpm and power the tko is impossible to get into 3 with out granny shifting. The carbon fiber syncro and brass shift tabs will help. Just sold my tko 600 due to this. Went a different route for now. The tranny was awesome when I only had 450 h.p. and was shifting at 5500 rpm.
Old 01-29-2016, 01:17 PM
notime's Avatar
Well its getting a stage III kit installed, should fix it.
Old 02-26-2017, 06:10 PM
Formula8's Avatar
Formula8 Formula8 is offline
Go to driving technique: http://www.tremec.com/anexos/TKO_Ins...ps_117_117.pdf
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Featured Vendors
Advertising Info
