Old 09-21-2015, 10:51 PM
rare4k's Avatar
rare4k rare4k is offline
I may have that
Old 09-22-2015, 07:20 AM
gtospieg gtospieg is offline
I have a GM limited slip unit I just removed from my 69 rear in favor of an Eaton unit. It had 3:55 gears...not sure if it will accept 3:23. I'm sure someone here will set us straight.
Old 09-22-2015, 06:33 PM
hdpontiac hdpontiac is offline
Default limited slip unit
please let me now if you have this unit and if it will fit the 323 gears thanks
Old 09-22-2015, 07:29 PM
ponyakr's Avatar
ponyakr ponyakr is offline
I assume you already know that Auburn makes new units, that will work with the 3.23's ?
http://www.justdifferentials.com/AG5...5420114-hp.htm
http://www.ebay.com/itm/Auburn-Gear-...25.m3641.l6368
http://www.summitracing.com/parts/au...GSKRoCnY7w_wcB
Old 09-22-2015, 07:36 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I have one in Ocean City, Md if you are anywhere nearby. I broke my 3.23 ring & pinion, but I believe everything else(posi carrier, axles, & housing) are OK. Was the original rear from my 69 GTO, which was a one wheel peel from GM. Posi was added by a previous owner.
