#121
#122
Just a thought as was mentioned. Monitoring Air/Fuel with both intakes.
Charles
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
#123
Excellent plan...
#125
![]() Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft |
#126
Doing a few little mods,taking a bit of weight off the front end,reducing rolling weight,adjusting intial timing,finally port matching my torker 2 for a start..
#127
Any updates?
Thanks Charles
#128
No real updates yet..I've ran the performer rpm a few weeks ago...its in the other thread...I'm presently doing a few tweaks..hoping to knock down the et and raise up the mph.Goal is another 11.3x timeslip this year at 120...first one was wind and weather aided..
#129
Weather permitting finally hitting the dragstrip Saturday,and a few more times this year.Just installed a Hughes th 350 with a low first gear set,seems to work good!Replaced front wheels with 15x4's and tires with M/T 165/85/15,dropped 7 lbs each side ,replaced 40lb battery with a Braille 2015 15 lb battery(works great),removed rpm intake and replaced with my Torker 2 which is finally port matched.Also replaced rear wheels which had quite a wobble to them...With good traction and decent air..should run in the low 11.3 range maybe quicker.
#130
Good luck!
#131
Sweet. You got a great combo there, good luck.
#132
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
#133
Yes different tranny altogether...did a few test runs on the street works good...,gasket matching and blending my torker 2 this week...also found my vacuum port plugs weren't flush with the top of the inside of the runners,have made all three almost flush,and will be when I'm finished.
#134
Went to the track Friday...had to test the port matched Torker 2 and new transmission under full power with a timeslip...Track was not prepped and very slippery..spun hard after initial launch..ran a 11.6780 at 120.37,60 ft was 1.7619 with a hard spin ...pretty content with that...mph was even with the best ever..tranny worked fine,shifted quick,engine is much happier again with the Torker 2 back on...Heading to Grandbend Motorplex Friday on a much better track..see how it does.Car should 60 ft in the low 1.6's with the 3.08 gearing and 28 tall tire..
#135
Thanks for the update.....do you think traction issue was strictly track related, or do you think the steep gear set may have been to blame?
#136
Track for sure ..had four hours of rain during the afternoon..very minimal track prep for evening...
#137
Hey Ernie,
Thanks for your extensive testing and feedback, particularly your success with using a 3200 stall verter and a 3:08 gear . My tight 10" Continental works great with the tall gear and I dropped 300 rpm @ 75 over my old 3:42 gear in my 550hp TA with no detectable change in acceleration .
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins Last edited by wheelspin; 09-23-2015 at 08:27 PM. |
#138
On a side note..my new tranny as recommended by the builder uses Type F...I flushed my convertor,cooler and lines to insure no Dexron left...and I swear my trap rpm is down slightly..not like it was an issue.I wonder if the Type F has tightened up the convertor slightly...? |
#139
Did testntune last night at Grandbend Motorplex ran three times..11.408 at 119.96 with a 1.731 60ft,11.457 at 118.82 with a 1.718 60 ft and a 11.435 at 118.73 with a 1.714 60 ft.
Last two runs were into a good headwind..pretty content with the times with the soft 60ft...a bit of fine tuning could drop the 60ft times.My fuel pressure also now drops to 3 lbs by half track which is an issue. I did manage to outrun my buddy's Chevelle..we were betting on best timeslip for the night...he ran in the 11.5's with one slip at 11.45.He is 555 cuinch 110 octane 3.73 gears... |
#140
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
