#161
Old 09-24-2015, 12:17 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Adam, tune the carb and distributor for best idle quality, off idle smoothness, throttle response, and drivability in the "normal" driving range.
If the carb is lean or timing insufficient you will notice loss of power, "flat" on light throttle acceleration, and even some "bucking", kicking, or you just have to apply to much pedal to make things happen. It other words the engine will let you know when it isn't happy.
Once you are happy with how the engine performs, fuel economy is good, and no lag or lacking power anyplace, etc, and you still think it's running a bit hotter than it should, attack that as a separate issue.
We NEVER under any circumstances want to "wash" the engine with too much fuel to "crutch" a hot running condition. Even the big 455 should delivery decent fuel economy. Yours should end up in the 12-15mpg range, depending on city/highway, fuel quality, wind speed/direction, driving style, etc when doing the testing.....IMHO.....Cliff
  #162
Old 09-24-2015, 12:45 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
you might try a 180 deg thermostat. The 160 stat you are using doesn't stand a chance of maintaining a steady engine temp and the wide range of temps you are seeing only make tuning more difficult. A 180 deg stat will narrow the range of engine temps you are see and simplify your tuning efforts. The 180 stat will not make you car run hotter. It will keep it between 185-200 rather than 165-200 like is happening now. It will raise the floor but the ceiling won't change.
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
  #163
Old 09-24-2015, 01:01 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
except that once warmed up the lowest temps I see now are 180. It never goes below there. (and I did verify the new T-state in a pot of boiling water. It was quicker acting than the old 160 I removed)
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #164
Old 09-24-2015, 02:41 PM
PontGuy's Avatar
PontGuy PontGuy is offline
Cliff beat me to the punch. For gas milage to be that bad the Holley must have been running pig rich on the primaries. Probably good for cooling things down but not so good for the engine (or the cost to operate it!)
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
  #165
Old 09-24-2015, 05:22 PM
Cliff R's Avatar
+2, 3, 4, 5 and 6!!!
"As for MPG, over the last year, I've been seeing around 6.1-8.1 under most driving conditions, excluding trips where I did a lot of tuning and idling in that tank of gas, so I'd say the average was around 7.8 before. On the only tank of gas that I've run post-Qjet and post valve job that excludes tuning work, I got 12.1."
7.8 MPG average is ABSOLUTLY UNACCPEPTABLE. It tells me that something in the mix is WAY off someplace. It's often a combination of things, but I can tell you or anyone else reading this for certain, a stout 455 with iron heads, around 10 to 1 compression, and well chosen camshaft will just about double that number for fuel economy when correctly tuned.
I've had half a dozen engines in my Ventura since the late 1980's, from 406cid to 468, and gear ratios from 2.73 to 3.73, and ALL of them got over 12mpg's, and the 406 with 2.73 gears just under 20 mpg's.
Even the current 455 is very thrifty on fuel. It uses no more fuel for "normal" driving than the last 455 did. I checked the last engine for fuel economy several times, and it would EASILY make 180 miles per tank (about 14.0-14.4 gallons), and I've had a few tanks in the 200-230mile range when there was considerable highway driving involved, and the operator had enough willpower to stay out of the secondaries (seldom happens).
Even the big Holley carbs I've ran and tested, and the POS Edelbrock AFB clone would muster 160 miles per tank, which is closer to 11mpg.
Adam, I would NOT under any circumstances put the Holley back in service in it current state of tune, it is "washing" the engine for sure consuming that much fuel, running cooler or not......FWIW......Cliff
  #166
Old 09-24-2015, 05:42 PM
AdamIsAdam's Avatar
Cliff, no worries about the Holley, it's long gone
One change I made is that I used to run 100 octane, either straight in or mixed 50% (more or less, depending on when I got to the pump). And yes, at nearly $10/gallon, that was a lot! Then you pointed out to me that if I'm not pinging, I'd likely go slower with higher octane. So I stopped putting that octane in. Maybe that has something to do with my temps rising? That's what someone else suggested. It's worth a try checking, now that I'm logging my data more carefully.
Speaking of data, I checked the dates on some of my pictures and it looks like my temp issue actually started before I installed the Qjet, even before I changed intake manifolds (I ran the Holley on the new intake for about a month). I know it definitely got much worse when the Qjet went on last November, but the problem was clearly lurking before. So I must have a few things going on as you said before, Cliff.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #167
Old 09-24-2015, 08:28 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Default Radiator
Adam,
What radiator are you running? More importantly how old is it and when was it last PROFESSIONALLY cleaned? A little scale goes a long ways in reducing cooling capacity!
The other question I have is about driving conditions. You state that the real issue shows up after highway driving and disappears once you get off the highway, correct? If it stays cool even in city traffic jams but gets warmer on the highway that is a hint. Under 40mph the fan/fans are in charge, but at highway speeds air feed from the front of the car, ie air dams, grills and such are in charge. Have you mounted a new cooler for the engine or transmission in front of the radiator?
Karl
  #168
Old 09-24-2015, 09:57 PM
AdamIsAdam's Avatar
My radiator came with the car. It looks like a generic brand. Oh, and during a nice highway drive it still hit highway temps.
Her is what I have, which is how u bought it...
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #169
Old 09-25-2015, 06:01 AM
Cliff R's Avatar
You may be able to cure the heating up issues simply by installing a heavy duty thermostatic clutch fan. They pull a BUTT LOAD more air than any electric fan set-up.
Even on my 455 which doesn't even think about heating past 180 for any reason in any weather didn't like the electric fan set-up much. It did OK, but it kept killing my battery if I used it to keep the engine cool on hot summer days at the track. I went back to a HD clutch fan and never looked back. I can cool the big 455 with a stock Modine 3 core radiator that's over 25 years old at this point.
I'd also put that cam on the endangered species list. 276 degrees seat timing isn't nearly enough for a 455 Pontiac engine at 10 to 1 compression, especially ground on a 110LSA with the ICL down at 106. It's better used serving a 400 engine build about 9 to 1 compression, if one goes that direction at all.....IMHO and FWIW.......Cliff
  #170
Old 09-25-2015, 06:43 AM
AdamIsAdam's Avatar
Yes, I may look into the clutch fan. And yes, I know this cam isn't ideal for this engine. Remember, I didn't put it in there.
Corrected picture from last post:
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #171
Old 09-25-2015, 08:18 AM
PontGuy's Avatar
Looking at the pic Adam that electric fan setup looks very restrictive for highway driving. A factory clutch fan with a proper shroud might even get you to 180 down the highway just like Cliff's car!
Just for the record, both of my cars also have factory shrouds and clutch fans. The Lemans tends to run around 190 down the highway in warm weather. The T/A gets up to 200 but it has an A/C condenser and massive trans cooler in front of the radiator, and the timing is pulled back because it still has the XE cam. I put an aluminum radiator in it to help keep the temp down but kept the original to try when I get around to putting a proper cam in it and get the timing set right.
One thing you guys don't have to worry about living up north is the hot summers here. Temps typically are in the high 90's mid summer, but then again its not much fun driving these cars in that sort of heat. They just stay in the garage when it gets near 100.
  #172
Old 09-25-2015, 08:24 AM
Cliff R's Avatar
For sure the cam isn't helping you anyplace. I've tuned enough Pontiac engines using those cams to know to avoid them completely. Typically they want more fuel and less timing, telling me that the short seat timing events aren't making things more efficient, at least pound for pound compared to more ideal choices.
I try to stay off the subject, because I quickly get called the Comp XE "cam basher", but I really only mention these things to help folks make more educated decisions and to get a better end result all the way around.
For absolutely sure 455 cid and a solid 10 to 1 compression needs more cam than 276 degrees seat timing to make optimum power on pump fuel, and to effectively manage pump fuel with "normal" fuel and timing curves. When the cam is too small, and intake closing too early/LSA too tight, one will often run into many of the issues that you are here, which include running hotter than it should be, just to mention one of them......Cliff
  #173
Old 09-25-2015, 08:40 AM
AdamIsAdam's Avatar
Good food for thought. It's on my list... to change the cam which would be an excellent time to change the electric to a clutch fan. Hmm. Would I be able to use my existing radiator or is it not the right size? I guess I'll waddle on over to the cooling section and see what fan and shroud options there are.
Thanks for all the feedback. And Cliff, I still have your recommendations as to which cam to go with for when I'm ready. don't think that was a waste of time by any means.
Thanks.
Adam
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #174
Old 09-25-2015, 10:32 AM
Cliff R's Avatar
The size of the radiator certainly becomes less important when the basics of engine operation aren't dumping a TON of heat into the jacket water.
I'm found out that having a successful engine build starts with the basics, which include optimum quench, compression, cam choice, intake valve closing point (where you put the cam), carb/distributor tuning, to name a few.
For sure all of these engines need an efficient cooling system. I've never really seen any negatives from too much radiator, but I have seen folks install HUGE radiators to combat fundamental issues and still end up with a pretty hot running engine.
With my current engine I see negatives every Fall and thru the colder months, it just runs WAY too cool/cold, and refuses to heat up the coolant in what I would call "normal" conditions.
My last two engines have been like this, they just take FOREVER to reach operating temperature, unless it's 90-100 degree days, and even then count on a solid 15-20 minutes of running time before it gets past 160 degrees, even with a 180 stat in it.......Cliff
  #175
Old 09-25-2015, 11:17 AM
AdamIsAdam's Avatar
There are many people who hate you for this sentence, ya know!
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #176
Old 09-25-2015, 11:51 AM
PontGuy's Avatar
Yeah Cliff is good at pointing out what is possible, not necessarily what us amateurs should expect. Sort of like watching pro golfers pound out 340 yard drives. (When I play a bunch I average around 270 yards off the tee, and that's about where my Pontiac expertise is on the relative scale.)
Its really been interesting having two cars with engines that are set up very similar except for the cam. It takes my Lemans a good little while to come up to temperature with the long seat duration cam- seems like forever in cool weather. The T/A is up to temperature in a matter of a few minutes with the XE (and necessary retarded timing.) But at least the T/A heater works quickly during the winter.
  #177
Old 10-24-2015, 10:41 AM
AdamIsAdam's Avatar
Update: check out this oil pressure now that I got temps under control.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
  #178
Old 10-24-2015, 11:50 AM
craigs69's Avatar
craigs69 craigs69 is offline
The 400 that came in my car always ran between 210-230 degrees. It was a stock 1977 400 with untouched 6x-4 heads, hydraulic cam that was way to big for the combo, Edelbrock Performer, Q-jet and a Ebay $50 HEI distributor. The cooling system on the car was a factory water pump with divider clearanced and a 3 core factory radiator. When I rebuilt the car in 2012, I replaced the radiator with a 2 core aluminum piece with 1-1/4" tubes, replaced all of the missing seals on the core support and added the lower air dam on the bottom of the core support. All these things together brought the temps down to the 200-205 degree range.
In 2013, I had my current 469 built by Calvin Hill. We used a 455 block, #48 heads that he ported to 235 cfm and a Lunati SFT cam selected by Calvin. The block is zero decked and the pistons are 29cc dished, giving me a cranking compression between 165 and 170 PSI. I sent my Q-jet and Pertronix distributor to Cliff for him to work his magic and recently added a ported cast iron intake. On 90 degree days, this engine does not ever climb over 195 degrees regardless of how hard I drive it, and on days under 50 degrees it never gets over 175.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
  #179
Old 10-25-2015, 08:57 AM
PontGuy's Avatar
I've been watching along on all your cooling threads. It looks like you have confirmed that the restrictive shroud was causing a problem on the highway, but I bet that you will need a shroud in traffic during summer heat. At least you have six months or so to consider how to tackle it if that becomes a problem.
  #180
Old 10-25-2015, 03:46 PM
AdamIsAdam's Avatar
Exactly my plan for the winter.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
