| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I have a similar type stove, but not plumbed into the HVAC. In my experience it is much easier to keep a fire going without a grate because the wood stays on the bed of coals. With a grate. the coals fall through and are not in contact with the wood. My process for building a fire is:
1) place two sticks of kindling in the ash bed 2) put two firestarter blocks on the kindling and lay 4 pieces of fatwood against the firestarter blocks 3) add 3 more pieces of kindling on top 4) crumple 2 sheets of newspaper into balls and place on top of kindling 5) light the firestarter blocks and once they have reasonably ignited also light the newspaper 6) close the doors and make sure the air flow is wide open 7) fix a drink and go to the garage 8) once the drink is done, go back to the fireplace and add two or three pieces of wood. I usually try to add two smaller pieces and one bigger piece at this point 9) once this starts to burn down and create coals you should be able to burn about anything You can greatly control the rate of burn with the air flow control. Load it up at night and choke back the air and there should be coals in the morning. Good luck. I lit my first fire of the season last night and am still enjoying it. |
That may explain why there are about 10 bushel sized boxes filled with fatwood in the barn. STACKS of covered wood all over the yard. KS contractor guy in the video says he heats his home(s) with it & burns 1 truckload a month. About 3 fires/fills a day. That is just a little more than I have used in some air tight stoves to heat old houses.
No sun here for about 7 days has got it chilly. Thinking of testing it out soon while I am working there. Will try the drink method once I get moved in.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 |
If you have used a wood stove before you will use the same method for that as you do with the combo stove. I used a wood stove in my last house for 10 years & have been in this house for 28 years. I started to burn wood here about 6 years ago & now wonder why I didn't do it sooner. I love the way wood heat feels, it is so much warmer feeling then gas heat. The heat is all around you & the house doesn't get cold & then warm & then cold again. Plus using wood is a lot cheaper even if you don't cut it yourself. In the worst parts of winter It costs me about $ 65.00 a month in a 1500 sq. foot home. Wood is good.
Oh yeah, I have decades of experience heating with wood, but all the FP inserts I ever saw were nothing compared to a wood stove and never saw one that did not use a grate. Not saying much since I did not consider them viable until reading about this one. Most of the ones I have seen heat was wasted and went up the chimney, even on the ones with blowers. This thing is more like a stove that is made to look like a fireplace. It is not an insert. Has 2 heat exchangers and the air inlet (from outdoor source) blows directly on the bed of coals. It can be used straight convection w/ heat coming out the vents on top of it or running through the duct system. Pretty sure it has to have the air circulating w/ fan or risk damage to overheating from reading the installation manual.
The 2 best stoves I have used from the old non-catalytic era were Temp-Wood, a top loader down draft stove and a Fisher, which was a front loader. Both are worth their weight in gold today. Both of these would heat large poorly insulated houses to the point of comfort when temps don't go ago above freezing. The stuff they have now with the converters and the like simply can not compare to those stoves. My place with the Century also has a Tulikivi that I think is a 2200 model that weighs in at over 4500# of soapstone, so I should be able to heat 3k SF with both of these devices no problem. Just don't want to screw up my new paint job messing with something I have never used before. Here are Pics of the 2 at this place I am working on:
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 Last edited by Deadhead; 10-04-2015 at 02:11 PM. |
I've had 4 wood stove over the years & the one that in the house right now is the same as my last house & in my shop. It's not made any more , well they build a type of it but it's an insert only now. It's called Blaze. They made 3 different sizes , the King, Queen & the princess. I have the Blaze King in my house right now & it has a bi-metal t-stat in the air opening to regulate the incoming air & during the coldest weather it will stay within 3 degrees & on a full load will last about 10 hours. It's a front loading with the stone liner in the bottom to keep the heat at a constant temp. It is an older one without the cat con built into the stack. This is my 2nd Blaze & i got this one about 6 years ago & it works great keeping the house comfortable in the winter.
I can't believe you are more excited about the Century than you are the Tulikivi. Have you researched it yet? I am a fireplace (fire) nut and have wanted a Tulikivi for years. That thing is 4200 lbs of thermal mass that will radiate heat for a day after the fire dies down. You lucky dog. Please update this thread after you fire it the first couple times.
That stove is in a more isolated room where I have a return I have moved near the stove to suck some air back into the HVAC. Then it has a window in the top of the room open to a bedroom. It does not seem to me like the location is going to allow it to do as much for the house as the Century. As a side note. I lived in an old company house originally part of the Alberene Soapstone Co. on my current property before I built. It had chimneys made of soapstone bricks. We used a Monarch cook stove to heat that place. The chimney would stay hot for about 18 Hrs after use. When I built, I lined all my hearths and fireplace surrounds with those bricks, which I found in the woods. My current FP uses a Texas Fireframe grate, and heats pretty well. If you have not see one of these, it is worth a Google. I have been using them for 30 years. They will run you out of a room with ANY conventional fireplace. $125. The stones on the hearth will hold heat for OVER 24 hours. Century thing at new place has a similar hearth, but I doubt it will absorb as much since there are airtight doors on it.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 Last edited by Deadhead; 10-05-2015 at 07:29 AM. |
