Old 10-16-2015, 11:24 AM
Tim Corcoran's Avatar
I believe that a 100 amp alternator is more than you will ever need unless you have one of those big ghetto boom boom stereos or something unusual that draws a lot of current. With regards to battery cables bigger is almost always better and it's hard to go over kill. One of the reasons I use welding cable, it is more flexible and easier to route,carries more amps and has lower resistance than a standard battery cable of the same size. I use the Ford style solenoid on the firewall or fenderwell, AWG 1/0 welding cable from battery to solenoid, solenoid to the starter, battery to the frame, frame to the engine. Also a good size ground from each cylinder head to the firewall. This is a trouble free system that will never have any hot start issues.
Tim Corcoran
Old 10-16-2015, 11:48 AM
Willshire's Avatar
Willshire Willshire is offline
Originally Posted by Nicks67GTO View Post
FWIW RobbMC told me #4 was unacceptable for pushing their starters and I was having an issue with my cables so I went to a supply store and had them make me 1 Ott cables both positive and negative. Overkill on wire size never hurt anything but your pocketbook.
The locked rotor current of the starter will be over 300% of the running current in most cases. It is the biggest load on the whole system, good thing it is only intermittent.
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 10-16-2015, 01:32 PM
David Jones's Avatar
I think to say that "most" welding cable sheathing isn't oil and chemical resistant is a gross overstatement. Most welding cable sheathing is very oil and chemical resistant since it is generally a neoprene/nitrile material.
Old 10-16-2015, 01:50 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
I put Auto Zone Duralast Gold on my 69 GTO and have no starting problems. They are 2 gauge and really cheap. That's with a Robbmc starter. The car has AC and in the summer it gets real hot but I have no problems with starting it. Fires right up every time.
They make them for 2nd gen firebirds. Cheap and easy.
Old 10-16-2015, 05:18 PM
455rebel 455rebel is offline
My local napa makes custom cables for 18 wheelers, and anything else u need!
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 10-16-2015, 08:06 PM
The GOOD cable material is also very "Abrasive Resistant" as the cables are constantly being dragged over concrete, rocks, steel beams, etc in a normal welders day of work.
A typical starter cable is purchased, mounted, and forgotten, except for cleaning of the corrosion on the cable ends.
Old 10-16-2015, 08:38 PM
my69brd my69brd is offline
This guy sells amazing wire and might make custom cables
http://www.ceautoelectricsupply.com/
Old 10-17-2015, 11:58 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Im using a #2 welding cable on a trunk mount battery application with compression style cable ends. - https://www.youtube.com/watch?v=nBP0pMUNLaU -
No problems starting a 9.6 to 1, 455, with inital timing at 12 btdc.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 10-17-2015, 12:54 PM
I use 1/0 low oxegen Cu. cables for grounds and starter, alt., main feed to fuse box.
Old 10-17-2015, 01:27 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Most people, it seems to me, way overthink the starter cable thing. The starter is, by far, the biggest electrical draw on the entire system. 200-300 amps, depending on starter type, and load. You only need a cable large enough to carry that current, for the distance it has to travel. For under hood battery applications, 4 gauge is plenty of cable for the starter. 2 gauge is the most you should ever need. If the battery is in the trunk, then I would step it up to 1 gauge. Any cable large enough to operate the starter, will be double the cable you need for charging the battery. Since electricity travels on the outside of the wire core, the more strands of fine wire it has, the better. Welding cable has very fine wire, and lots of it. This is why they don't run solid core wire in cars like they do in houses. The more the voltage of the system, the less wire gauge you need, because the amperage draw drops accordingly. 6 volt systems need even heavier battery cable because the voltage is simply not there to push the amperage through, so they need as much wire strands as they can get.
Standard car battery cable is all anyone should ever need, whether it be 4 gauge, 2 gauge, 000 gauge. Anymore than than your system needs is a waste. After doing starting and charging systems for 11 years[and 10's of thousands of cars fixed] I am convinced that 1 gauge is the heaviest cable anyone would ever need to start their Pontiacs. Anymore than that is a waste.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-17-2015, 03:42 PM
My question is still WHY use welding cable when SAE or ISO rated auto cables are available, and can be roughly the same cost?
http://www.champcable.com/product_pd...Comparison.pdf
" SAE and ISO committees develop standards for wire and cables used in trucks and automobiles. These standards are designed to ensure wire will perform safely and adequately in the harsh environments that vehicles are subjected to on a regular basis. The committee members have years of experience in engineering, design and development work for the automotive and commercial vehicle industries. Listed below are actual test result and pictures illustrating the type of catastrophic failures that can and will occur using the wrong type of wire, such as welding cable! "
Most of the welding cable I've seen doesn't have any markings on it, so you aren't sure what it's rated for, not to mention it's larger in diameter. Then there's also EMI to consider. Why don't OEs use welding cable?
All I can say is use what you want, I know what I feel safer using. Just because 'it works' doesn't mean it's the best choice. There's a spec for auto use, why not do some homework on it instead of taking other's word for it?
Old 10-17-2015, 09:44 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I agree, and my experience says the same thing (I do high current charging systems for a living but that's just an aside). My only reason for using 2ga on my cars is that most of the generic parts store 4ga wires, while passable, aren't exactly that stellar for the long haul. I've never had a problem with 2ga and I've got some on a car that are 10+ years old and work perfectly still, even in +100F heat.
Old 10-18-2015, 09:16 AM
Bobalong Bobalong is offline
Just as thought as I read this thread.
The previous owner of my 70 GTO installed the RAlll exhaust manifolds. In addition he installed the tube that the battery cable passes thru.
It leads the + pos cable right between the hot cast iron manifold tubes on the drivers side down to the starter.
Now I pride myself on having a pretty factory stock looking car. Not 100% mind you but pretty close. In 08 during the first engine rebuild I eliminated that tube. I'm sure the Pontiac engineers had their reason for that cable route, but it just defied common sense to put an unfused, heavy cable right in harms way.
I bought a longer red cable and routed it down the front of the engine and then back to the starter. Is it factory correct ? NOPE. Out of harms way and I no longer worry about a melt down, short circuit, or catastrophic under hood fire.
Old 10-18-2015, 09:26 AM
I run my POS cable over the top of the drivers inner fender and then down the firewall. Other than the few inches from the battery to the fenderwell, you can't see it at all.
Old 10-18-2015, 12:19 PM
I did the 67 RA manifold Battery Cable routing on my 64 when I installed the Manifolds on the engine.
1) The Pontiac Engineers did the Battery Cable routing change for a reason.
2) I emulated what they did.
3) I was able to use 1/0 AWG Tinned Copper Marine Terminals. (Copper die casting tinned battery terminals resist corrosion and are superior in Marine environments. They have high amperage flow for optimum performance.)
4) I heated the terminals, added the proper solder, and no issues for many, many years (with a touch up on the battery terminal and cable end with the proper wire brush battery terminal/post cleaning tool).
Old 10-18-2015, 01:07 PM
gtofreek's Avatar
I agree. There is no real need to have to use welding cable. Regular automotive cable will work just fine. I will probably use 2 gauge on my GTO, as I am not planning on putting the battery in the trunk. At least not for now anyway. When I had my battery in the trunk[8D tractor battery], I ran 1 gauge cable to the front for both positive, and negative. I built a super torque starter for it. One day, my distributor took a dump so I had to crank my car home with the starter, in first gear, shifting to 2'nd when it got rolling. Cranked it for over a mile to get home. Wore the brushes down on the starter, but the cable, the rest of the starter, and battery held up fine.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 10-18-2015, 01:14 PM
gtofreek's Avatar
This is exactly why I use a Ford starter relay to feed power down the heavy battery cable to the starter, and solenoid. I use a jumper from the battery post on the solenoid to the "s" post on the solenoid. This way, there is only power on the heavy battery cable when the engine is cranking. No worries about it shorting while driving. Also, you only have one wire to connect on the starter solenoid. A much better system than what the factory did. Also, don't think of the Ford starter relay as a Ford part on your Pontiac. Instead, simply think of it as a starter relay to improve/fix the factory starting system, which kind of sucks, really.
Ford got that one right! After all, you never hear of a Ford with a hot start/no crank situation.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #38
Old 10-18-2015, 05:04 PM
All I can say is use what you want, I know what I feel safer using. Just because 'it works' doesn't mean it's the best choice. There's a spec for auto use, why not do some homework on it instead of taking other's word for it? .
Racers have used Copper Welding Cable since the 1950s in their race cars.
Most automotive battery cables today are designed on the premise of "use the cheapest material that will pass the minimum specs to get the job done."
Copper prices have been high for years. The manufactures run durability tests to find the cheapest material and design that will pass the tests. (They ARE trying to make money on the cars they sell.)
Everything that you say is true but copper Welding cable is not inferior to OEM wire if used in a proper racing application. There are no cold temps, water ingestion, desert dust, or oily environments (if the engine is sealed up properly) to worry about.
