What type of 2 Barrel on the Motor? I ask because if this 59 was and "E code"
engine, it may have come with a small base Carb with a large/small dual base bolt pattern. This is called an E-Carb, and would be one of the very few Bolt on Center Carb options for 59 to 65 Tri-power. Found one of these on a 59 Wagon a while back. The Standard Engine/Carb would be a large base standard 2 barrel, but would use the same intake. This would be the same up to 1962, and most folks refer to this as the Taxi Cab option. Rare Carbs, and difficult to find. |
Since this is an 'A' code 280 HP engine I doubt it has the 'E' carb but during 56 years anything could have been swapped in order to keep it on the road.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
