Old 10-26-2015, 06:51 AM
necdb3's Avatar
necdb3 necdb3 is offline
I am struggling to get a uniform texture on a formula wheel hub and need advice.
I primed it with a rustoleum aerosol, wet-sanded smooth with 600, then used VHT wrinkle paint. It sprayed great and looked very uniform when wet, but came out non-uniform when it wrinkled, and I'll have to strip and start over. I'm disappointed and want to try and get it better next time.
I also think the wrinkle texture looks pretty rough, but have never seen an original black one. My hub started out red, so was from a TA, and had a somewhat rough texture but not wrinkled. Was the original wrinkled or just rough-textured?
The VHT black also looks too glossy to me, even wrinkly.
Did I mess it up or should I try a different brand? Is there a trick to getting it uniform with a spray can?
Should I eliminate the primer?
Would I be better off using a RustOleum textured spray instead of a wrinkle finish?
I did not use primer on my column and it turned out great. That was 9 years ago and it still looks great.
Dave
