Old 11-06-2015, 11:28 PM
Originally Posted by JD311 View Post
I thought all 59 blocks had the same casting number?
I'm digging for a piece of paper I have that had all the numbers of both blocks(saw it recently too)... I recall having a hard time verifying what the AN420 was as the only published casting # I could find was the one you have.(the one I still have as well.)
Everything on that AN motor was March or April casting/build dates including manifold and carbs. Vin stamp matched the 59 Catalina. If I'm not mistaken, I believe it was Tom S back in the very early "CP" days that told me for sure it was a 59 casting.
The 59 that didnt get away came with the Catalina when I bought it. I almost passed on it because it was deep in the ground with the pan rotted badly... I threw it on the trailer only because the guy was going to scrap it if I didnt take it.
Turned out to be quite a neat piece. The original owner of this stuff had died in a car wreck on New Years day 63. Car eventually went from familys garage to field behind the barn.
Several months after having the motor sitting in my barn I noticed the ports on the heads were heavily taped up. So I dragged it over to my workshop area with better light and decided to pull the tape. Ports were nice and shiny with plenty of evidence of a port/polish job. Pulled the crusty stock valve covers and found the mice had quite a hotel built. All rockers had been backed off(lock nuts over regular nuts). some light rust here and there on generally shiny light weight pushrods.
I had to pull the heads(which were 1960 heads fitted with the 55-59 gusher tubes)...I found immaculate bores/chambers, stock valve sizes, along with a coat of dried up oil(waxy) on cyl walls. Had victor head gaskets on it. Oil passages to heads were blocked of with set screws. Pistons were domed and highly polished with NO valve notches...this was getting real interesting.
I pulled the lifters and found they were solid edge orifice type. Pulled the timing cover and and steel geared timing set and found I had the old Isky E2 grind Pontiac cam in it. Balancer was the early SD type but badly deteriorated from the weather . Flywheel was a Harvey Aluminum piece. Sadly galvanic corrosion had set in and when I started removing clutch bolts I tore chunks out instead. Clutch face and flywheel had no signs of wear.
In process of removing flywheel the crank started to rotate. Off came the oil pan and a half hour of cleaning out the mice's grand ball room...I find the oil pickup brazed to pump and dip stick tube brazed to windage tray. After wiping lower exposed bores I find they arent rusted, just a dirty waxy film(old oil?). I spray a bunch of 50/50 marvel mystery oil/WD40 on cylinder walls (upper and lower) loosen all caps I could and spray the mix around the edges and rotate motor till I could loosen all the rod caps. I pull the pistons and rods out and find early SD rods and JE on underside of pistons.
There are NO signs the motor had ever been run. No carbon found anywhere. The main and rod bearings are darker grey than new but no scratches. Cylinder bores are fresh crosshatch a few with light stains where the rings sat. Bore is at @4.12
(The AN had same pistons but 4.21 bore and domes not polished on standard rods and Engle hyd cam)
The armasteel crank is very nicely detailed and counterweights smoothed and rounded nicely. considerable detail at oil holes(straight shot oiling btw), and one of the balancing holes is filled with braze.
The block has been well detailed, especially the oil passages, especially in the main bearing intersections.
The outside of the block had very little rust and has some original paint under a slightly lighter shade. Water jackets are just hazed with rust, no crust to be seen.
The 59 distributor had a dual point conversion in it(SD perhaps?), the car had an old SD tach. The AN motor also had original long branches on it. The Cat had a homemade heavy steel clutch sheild welded to the frame. Car had been converted to floor shift and came with a 3 speed with staight cut gears. Odometer was a bit over 31k. Found the car outside of Fulton NY.
Calvin Hills Dads car came new with same options and color scheme(inside and out) and similar build dates. Unfortunately mine had sat in a field too long and needed more love than I could give it... despite sitting thru decades of upstate NY winters the chrome and especially stainless were very nice. At one point I wanted to build it as it was then evolve it a few years later.
Someone built a fairly serious motor for back in the day!(possibly early 60's superstock or modified production? Stock class cheater?)
The ported 1960 heads(w/gusher tubes) and 58 timing cover have gone to Atlanta for use on a 301T block build. The tripower and 1959 "x" heads, E2 cam and lifters pushrods were sold. The AN block was last known to be in Ohio. I kick myself for selling the long branches. Still have the polished 4.12" domed JE pistons with pins and rulon pin buttons.(pay the freight and they can be yours)
