View Poll Results: Type of Camshaft in Your Street Pontiac
Flat-Tappet Hydraulic 166 49.11%
Flat-Tappet Solid 22 6.51%
Hydraulic Roller 106 31.36%
Solid Roller 44 13.02%
Voters: 338. You may not vote on this poll
Old 11-30-2015, 11:55 PM
Default Poll: Type of Camshaft in Your Street Pontiac
What type of camshaft are you running in your street Pontiac?
Here are the 4 poll choices:
Flat-tappet hydraulic
Flat-tappet solid
Hydraulic roller
Solid roller
Old 12-01-2015, 12:03 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Current engine being built is getting a 70's era Crane solid flat tappet with mushroom lifters. Over 400 lift at the lobe with a 1.65 rocker.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 12-01-2015, 12:27 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Mine will be a solid roller. Engine is in the build stage right now. I like my hotrod car a little on the extreme side.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 12-01-2015, 12:41 AM
Will Will is offline
Old Crane solid roller version of the RAIV/041. Isn't made any more but I got it cheap so decided to give it a go and it works pretty good!
Old 12-01-2015, 01:13 AM
Hydraulic roller when I build it.
Dr. Thomas Sowell
Old 12-01-2015, 01:44 AM
I have in my car right now the Crane Blue Print RA IV cam, & I've used this cam in the last 4 engines I've built. This cam is the same cam that is / was in my 462, 455 + 30 over. With E-heads performer RPM intake, RA IB cam , 1:65 rolloer tip rockers, Eagle H-beam rod, SRP forged pistons, Crane anti-pump up lifters, dbl roller chain & gears, Eagle cast crank, Pertronix Ign., 8mm Taylor wires, & topped off with an 800 cfm Q-jet,(tricked out) & an M22 with 3:73 rear end,RA IV cast iron exhaust manifolds, in my 73 GTO & it went 11:72 @ 122 mph. This was done on street radial tires.
Old 12-01-2015, 06:25 AM
grivera's Avatar
grivera grivera is offline
Stump Puller HR, combo in signature
Will Rivera
Old 12-01-2015, 06:48 AM
goatman65's Avatar
My cam is SFT. CC 290b6, sounds great on a 106lsa but I might go roller over the winter. I like a cam that shakes the car siting next to me,but want the performance to back up the nasty idle.
Old 12-01-2015, 07:50 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
Solid roller in the 70, 10:8.1 pump gas
Hft in the 68 for 20 years . Hyd roller 400 on engine stand ( back up engine)
Old 12-01-2015, 08:37 AM
The Champ's Avatar
I've got the Crower 60243 HFT in my 9.5 to 1 462.
Old 12-01-2015, 08:50 AM
Was a solid roller, 248/254 .625 114 Crower, machinist/builder talked me into a XE288HR (236/242 .520/.540 110) on a refresh, unsure if I will run it or not.
Old 12-01-2015, 09:22 AM
firechickenman's Avatar
firechickenman firechickenman is offline
SR in mine. Comp XE Street Roller lobes. 254/260 @ .050. 112 LSA and 108 ICL. Right at .650 net lift.
HFT in the wife's 76 T/A with my old 400. Lunati Voodoo 10510703 227/233 @ .050. 110 LSA and 106 ICL. Right at .500 lift.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 12-01-2015, 10:19 AM
68azbird 68azbird is offline
Solid flat tappet in my 9.4:1 462
It is easier to fool a man than it is to convince he has been fooled
Gator67's Avatar
Gator67 Gator67 is offline
HR in my GTO and '68 Bird…but I'm getting really tired of playing wac-a mole with lifters so not sure what will end up in my Formula's 535.
Old 12-01-2015, 10:49 AM
ANDYA ANDYA is offline
Nunzi spec solid flat-tappet in my 428 with 722 heads.
Old 12-01-2015, 11:01 AM
tom s tom s is offline
hyd rollers in 2 engines,one with solids on it soon to be changed to hyd.2 with hyd flat tappets.Tom
Old 12-01-2015, 12:22 PM
track73 track73 is offline
041 with Rhodes and 1.65 roller rockers.
Old 12-01-2015, 01:07 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
A bunch of Melling SPC-7\068 clones in my cars...
Old 12-01-2015, 01:13 PM
tooski tooski is offline
2 HF, 1HR
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 12-01-2015, 01:24 PM
Don 79 TA Don 79 TA is offline
3318/3319 XER 106LSA
