#4901
Old 11-26-2015, 08:19 AM
johnta1 johnta1 is online now
"It has been estimated that fewer than 500 total Firebirds and Trans Ams were ever sold to the general public."
I thought he was referring to the SD Formulas and TAs.
Now the Formulas were less than 500 total for the 2 years of production.
  #4902
Old 11-26-2015, 10:35 AM
njsteve's Avatar
njsteve njsteve is offline
1973 = 43
1974 = 58
total = 101
  #4903
Old 11-26-2015, 11:05 AM
Held for Ransom's Avatar
I can never understand how a high dollar restoration can be done and they have that engine turned dash with the RTS emblem on it?
(even looks like it might have the correct glove box door?)
Worse than that, it is the bezel with the pulse wiper/round turn signal unit.
  #4904
Old 11-29-2015, 05:50 PM
njsteve's Avatar
I was tightening up the lower heater hose clamp to the water pump today on the 73 SD Formula and had to remove the 80 amp alternator idler pulley assembly in order to get to it. So I finally got a photo of the EUN on the front of the block that is hidden by the idler bracket. The car was ordered by Enrico Stein on 05/09/1973, shipped on 07/19/1973 and delivered to him on 07/31/1973.
Here you go:
  #4905
Old 11-29-2015, 08:21 PM
Alvin's Avatar
Alvin Alvin is offline
Here you go:
  #4906
Old 11-30-2015, 08:32 AM
Thanks, Steve!
K112 cast date on the block I bet?
  #4907
Old 11-30-2015, 06:59 PM
Red Goat's Avatar
Red Goat Red Goat is offline
When you look at John's EUN list, some of the EUN's are out of sequence from the VIN's.
Did the EUN's get stamped at the engine plant and then pulled as needed from the stock rack for installation into a car?
  #4908
Old 11-30-2015, 08:10 PM
I believe they get stamped at the engine plant.
(if that's where they built them?)
With the SD's I think the 'out of order' was because of the SD situation.
They probably required special treatment somehow and some might have been taken out of order on the line for something.
(possibly waiting on some parts like manifolds/carbs/whatever, the car itself may be ready but not the engine?)
I know the cast dates on the block were just a few dates, so can't go by that for when the car was built.
Also, some numbers may be off quite a few compared to the normal engines, but there were a lot of engines (thus eun's) put in cars between the SD's especially the Formulas I would say.
I would love to find someone who worked there that could explain the procedure for this.
  #4909
Old 12-01-2015, 03:18 PM
Pontiac Performance Author
when I worked @ the Linden plant (65-67), if an engine failed on first fireup , the car was sent to "heavy repair" for another engine.
  #4910
Old 12-01-2015, 03:40 PM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
Hi all,
Had a message from Pat Smith few months back who had been approached by a publisher on doing a book just on 1973-74 SD 455 Trans Ams and Formulas. If you or anyone you know would be interested in having pictures of your cars in the book than I can forward you his email address or maybe direct him to the forum.
Michael
  #4911
Old 12-01-2015, 04:06 PM
Cool, Ken.
Did the engine have the engine unit number on it at that time?
And if sent back, the 'new' engine get the same eun or it also had it's own eun?
(plus was the sent back one recycled to another car?)
  #4912
Old 12-01-2015, 04:07 PM
njsteve's Avatar
Send him my way. I'd be happy to volunteer the Formula.
  #4913
Old 12-01-2015, 07:07 PM
Default Slight Problem.
I just got in touch again with Pat Today with all the interest on this Book.
Unfortunately he has told the Publisher he is not available for the next 16 months due to other projects and commitments and would not be able to dedicate the time to make the book right. The publisher is keen to push ahead and would most likely look for another writer.
The publisher is Cartech Books and Pat is sure it will get iff the ground just not with him but he will definately let us know when it does in the not too distant future.
Michael
Originally Posted by mscicluna007 View Post
Hi all,
Michael
  #4914
Old 12-01-2015, 09:33 PM
Bentwheelbob's Avatar
Wrong section I know, but WTF.....
I got all excited when I first saw this car because I would really love to have a Buc Red SD, and one with a 4 speed is even better. However, the more I look at it the more problems I see. All the front fender fasteners have been painted red, the left door weatherstripping has some nice red overspray, and it is obviously parked in a body shop with very poor housekeeping. Am I missing something? Here's the link....
Hohttp://www.hemmings.com/classifieds/cars-for-sale/pontiac/trans-am/1789472.html
  #4915
Old 12-01-2015, 09:40 PM
RamAir's Avatar
RamAir RamAir is offline
My daddy told me to never buy a claimed unrestored car sitting in a body shop.
  #4916
Old 12-01-2015, 09:54 PM
Alvin's Avatar
http://www.hemmings.com/classifieds/...m/1789472.html
Sez "unrestored" someone deserves attention to detail for all of that "Buc Red" overspray as you mentioned...and noticed the hood hinges and headlight buckets (driver side headlight wires and connector too ) w "unrestored" red
BIN @ $80k...so Sharktank - WIIW?
  #4917
Old 12-01-2015, 10:31 PM
njsteve's Avatar
Thanks, Steve!
Now don't make me ruin all that nice, original patina (grease) to get to it!
(I'll try to get a looksie this weekend)
  #4918
Old 12-02-2015, 04:15 PM
John: I don't think the eun was stamped at the assembly plant(BOP Linden). I don't know what happened to the pulled engines. I was a "driver" , heading to the time clock and working 8-12 hrs a day moving cars in and out of the plant. I did enjoy looking at the stacks of 421 HOs with tripowers and big manifolds while heading to the timeclock.
  #4919
Old 12-03-2015, 09:38 PM
TimsTA's Avatar
TimsTA TimsTA is offline
What is the component under the upper radiator hose? Battery kill switch?
74 Super Duty Trans Am
  #4920
Old 12-03-2015, 11:34 PM
Transamric's Avatar
I'd say you are right.
