| Pontiac - Street No question too basic here! |
| View Poll Results: Type of Camshaft in Your Street Pontiac | |||
| Flat-Tappet Hydraulic |
166 | 49.11% |
| Flat-Tappet Solid |
22 | 6.51% |
| Hydraulic Roller |
106 | 31.36% |
| Solid Roller |
44 | 13.02% |
| Voters: 338. You may not vote on this poll | |||
Lunati BMII in the GTO at the present time. New engine will have a HFT Ultradyne 280-288 that I have been saving for several years. With slightly worked 670 heads should be nice street engine. Can't afford a HR so have to use what I've got.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
"Old Faithful" Hyd roller from SD Performance in mine
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Still running the HC-02 cam and Rhoads lifters I bought from HO Racing back in the '80s.
"I fishtail through the lanes, and I make my tires squeal. Power at my feet, and glory at the wheel. I wind the windows down, let the wind blow through my hair. God knows where I'm goin' to, but me... I don't care." |
Pontiac 9779068 as mfg by Crane Cams 1980s
Hyd roller with solid roller lifters.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Voodoo 702 in my FB with 350, Voodoo 703 in the 400 nearing completion for my Lee-mans. HFT's.
"...ridge reamer and ring compressor? Do they have tools like that?" |
SD's Stump Puller Hyd Roller with Solid roller lifters
Lunati
Hydraulic Flat Tappet Cam. Torque Monster for 400-455 c.i. daily driven street performance vehicle. Excellent torque and horsepower production with heavier emphasis on the low to mid range. Will work in tri-power applications with larger 389-455 c.i. engines. Choppy idle! Advertised Duration (Int/Exh): 262/268 Duration @ .050 (Int/Exh): 219/227 Gross Valve Lift (Int/Exh): .468/.489 LSA/ICL: 112/108 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 1300-5500 Includes: Cam & Lifters (#71951PR-16) Part Number: 10510702LK Previous Part Number: 60902LK And it is a tq monster, pulls from idle to my current redline 5100rpm.
Best so far 1/8 et,8.90 on street tires, Since that I have added 400 heads. I call it a rat sleeper. |
Another stump puller hyd roller.
Lunati Voodoo HF 705 cam (previous part# 60905) in a .035 over 455 w/Rhoads and Harland Sharp 1.65 roller rockers
Advertised Duration (Int/Exh): 284/292 Duration @ .050 (Int/Exh): 241/249 Gross Valve Lift (Int/Exh): .527/.548 w/1.5 rockers LSA: 110 |
I really liked my 60310 SFT but recently swapped it out for an "old faithful" clone from PKMM. Saving up for a set of Crower solid roller lifters w/HIPPA. Hope to be up and running in the spring.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
summit 2802
HR, Comp 236/242 dur, 520/540 lift
UltraDyne Hyd. Roller from Bullet Cams.
Flat tappet hydraulics in both GTO's: Sig Erson HI Flo I in the '65 since 1981 and still going strong, and a Melling 068 in the '67 since 1990 and still going strong. Both USA made cams and lifters, before quality went down the tubes.
Jeff |
I have an HC02, a couple of 2802's and an Old Faithful Hyd Roller.
79 Trans Am 400 4 spd WS6 68 Firebird 400 Convertible 70 Pontiac GTO 2007 Pontiac Solstice |
Using HFT Bullet #307000 234/[email protected]
71 Goatman Hot Rods & Horsepower.......A diease for which there is no cure. 71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
#38
Comp Solid Roller, duration at .050 269/279, lift with 1.65 roller rockers .719 / .727, 110 lobe separation.
#39
Comp XE Solid roller 242 248 on 110LSA. Right around 600 lift.
Previously ran the old HFT UD 280 288 on a 112 - great street cam.
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
#40
Comp Xr 288hr 236 242 ground on a 112 lobe for supercharger..
