Asked previously here on PY within another thread:
"What is the seat pressure and installed height for the old faithful roller cam" Answer posted by Dave Bisschop: "To the OP, in most applications we use the Crane 99893 valve spring, installed at 1.790-1.810", I set the intakes on the tighter side of the tolerance, I test all the springs and always put the ones with the higher pressures on the intake valves, since the intake valves weigh more and also have the momentum of the charge pushing on the back side of the valve while the exhaust valve if anything has pressure pushing or drawing it closed and the valve is lighter. On my digital InterComp spring tester the seat pressures on a new set of springs will range from 147-157lbs typically @ 1.800" and 380-390lbs @ 1.200" open pressure." Side note, regarding pushrod length. To be accurate you should measure and then order. Also, and important, the mention of the Crane 99893 valve spring is for conversation here, and not a recommendation by me. Personally I'd choose something else. And always remember valve springs typically lose some pressure after run in and over time. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-06-2015 at 11:12 AM. |
If you mean measure the old ones I don't have them, If not how do I measure. Also what would you personally choose?
Verifying Pushrod Length And Rocker Arm Geometry
http://www.compcams.com/Technical/In...20Geometry.pdf Valve springs, two very good sources: .http://www.racingsprings.com/ http://www.kmotion.biz/springsintro.htm .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Also stated from someone within another thread:
"...the installed height in itself doesn't amount to a hill of beans. what you need to know in addition, is the COIL BIND HEIGHT, then you can calculate how much max lift you can run before reaching coil bind with the springs." .
