The most cost-effective (cheap!) tall covers are the chrome Moroso tall covers. They are good quality and nice looking.
Did you carefully look at the geometry of the SBC rockers on your heads? When I last did that (on '58 heads) I had to juggle valve stem lengths and pushrod lengths to get the geometry correct; then had to elongate pushrod holes for clearance.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
Hi there, yes thanks for the info, I used plastercine on the pistons to check piston to valve clearance and also had to machine the pedestals down to get the right geometry so the roller is running through the centre of the valve etc, pushrods don't seem to be rubbing but there is not much clearance about 80 thou, do you think that will be enough?
My GUESS is that .080" clearance is enough. But it should really be checked, from valve-closed to full-lift.
Correct rocker geometry implies more than just roller tip centered on valve. In fact, running a little off-center on the valve isn't a problem. It's more important to get mid-lift angles correct- roller center to trunnion center perpendicular to valve stem centerline, and pushrod tip center to trunnion center perpendicular to pushrod.
