This is for a SBC 350. Car runs fine on the highway and in park, but at a light she starts shaking a little, then off-idle she shuts off. She starts right up after. This happened mostly on some short hills.
Put in some seafoam and filled the tank with premium, she is running a little better, she stays alive but still stumbles. Should I add heet and change the fuel filter?
![]() 461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust |
carbureted or injected?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Carbed 1978 SBC 350.
Guy said car sat for 4 months without stabil.
would it have an reel rock carb on it?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Time to tare the carb apart and clean the crap out from today's Ethenol cut fuel, gas tank additive will not fully help at times !
Get a carb kit like a Walker and go thru it.
Give it a good cleaning and use the new accel pump included Record the stamped jet sizes and primary metering rods
Carburetor building & modification services Servicing the Pontiac community over 25 years |
suspect some plugs getting wet-fouled. Carb redo with idle enrichment may help close the Primaries.
