View Poll Results: Type of Camshaft in Your Street Pontiac
Flat-Tappet Hydraulic 166 49.11%
Flat-Tappet Solid 22 6.51%
Hydraulic Roller 106 31.36%
Solid Roller 44 13.02%
Voters: 338. You may not vote on this poll
Old 12-03-2015, 04:36 PM
78's 455 Lunati/Ultradyne when Harold was there 296/304 on a 112 HFT.
New motor for the '81 455 is a Stump Puller,Comp S HR lifters.
  #42
Old 12-03-2015, 07:55 PM
BB70's Avatar
BB70 BB70 is offline
Ultradyne solid roller.
273- 280 at .050
106 lsa
.626 lift with 1.5 rockers in a .065 over 400
Intake degreed to 100 atdc
  #43
Old 12-03-2015, 08:17 PM
Now I did have an US 259//262 solid roller in the 78 before the current motor and drove it some on the street, but I'm thinking that 273/280 on a 106 is not a good 'street" motor roller.
  #44
Old 12-03-2015, 09:00 PM
BB70's Avatar
I hope it doesn't scare the feeble ones or pollute the air to much Skip.
John
  #45
Old 12-03-2015, 09:10 PM
Mr Twister's Avatar
Crane Solid Roller. Engine is on the stand at the builders shop.
  #46
Old 12-04-2015, 11:27 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Crower 60243 / 461 / 9.6 to 1... Im happy with it.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
  #47
Old 12-11-2015, 02:40 PM
rad400 rad400 is offline
Crower 60210 229/239 @.050 480/500 with 1.50 rockers 108 LSA 406 #12 heads.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
  #48
Old 12-12-2015, 09:43 AM
chuckies76ta's Avatar
We use to run OldFaithful Hyd Roller, Now both Cams are Road Paver Hydraulic Roller from Dave at SD Performance
950 Quickfuel.
  #49
Old 12-13-2015, 08:54 PM
69 Limelight 69 Limelight is offline
Comp XE268H in .030 over 400 with #62 Butler ported heads @ 9.5.
  #50
Old 12-16-2015, 10:43 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
HFT in old motor; 296/305 ;246/253 at 050, HR Road Paver in new motor. Looking for more power, higher vacuum, and better idle with roller.
  #51
Old 01-26-2016, 08:56 PM
harley3296 harley3296 is offline
Pontiac 350, 9.5 compression, 274xe 110 lsa cast pistons, now #2 cylinder down on compression.
Now building a 400 with 218 224 @.50 112 lsa
10.1 compression
  #52
Old 01-26-2016, 09:44 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Kinda funny, I have a Lunati HFT in the race car and I'm going with a Comp 270S SFT in the street car.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
  #53
Old 01-26-2016, 09:50 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Stump Puller
color me gone
  #54
Old 01-26-2016, 10:39 PM
Solid Flat Tappet 255/260 .599/.614 lift 106 Comp Cams.
  #55
Old 01-26-2016, 11:28 PM
carcrazy carcrazy is offline
Comp solid roller in my 67. As I remember, 242/248 duration and a lift around .600
  #56
Old 02-05-2016, 01:07 AM
misaac misaac is offline
Currently UD hft 231/239 @.050 112LSA. Next build will be Comp solid roller XE series lobes 248/254 @ .050 on 110LSA. (if I ever get r done)
https://www.youtube.com/watch?v=XGf_pe66mOE
  #57
Old 02-05-2016, 03:40 AM
Gtowolf Gtowolf is offline
Comp 270 H #51-233-4 with 1.65 Harland sharp roller rockers
  #58
Old 04-02-2016, 01:46 PM
nachomax's Avatar
nachomax nachomax is offline
HR Hybrid set-up. Lunati Voodoo 231/239
455, Shaker455 Q-jet, #13 heads, KB dished pistons, approx. 9.1:1 Compression
https://youtu.be/qyqOtYxqIm0
  #59
Old 04-04-2016, 11:53 AM
android 211 android 211 is offline
068 in a '96' head 455, 1969 GTO. Automatic. 2.56 rear gears.
  #60
Old 04-05-2016, 10:28 AM
Pontiac Derek Pontiac Derek is offline
It makes my Heart Warm seeing so many Solid/Roller Set ups!!!
72 Cat stock short block, SD 270cfm cnc #17's 9.0:1 compression
Summit 2801 with HS 1.65 rockers, ported iron 4bbl by me and 850Q jet by me also
TH400 2400 stall, 2.73 gears 8.5" 10 bolt, daily driver, going for low 13's
Next Motor is Iron Headed 600hp pump gas Hyd Roller ;-)
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
