#41
Old 11-23-2014, 10:06 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Picked it up from having the 6 point roll bar installed on Saturday, painted it today.
ID:	382724   Click image for larger version
ID:	382725   Click image for larger version
ID:	382726   Click image for larger version
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
  #42
Old 03-07-2016, 12:19 AM
Installed a 455, turbo 350, PTC 10" converter. Headers are Headmen from a 67 GTO, Lemans, Tempest 1 3/4" primaries and 3" collectors. Bought six 1 3/4" U bends and four foot stick of 3" pipe to reroute seven out of the eight tubes and extend the collectors. Have $200 and about 15 hours into the headers
ID:	422976   Click image for larger version
ID:	422977   Click image for larger version
ID:	422980   Click image for larger version
ID:	422982   Click image for larger version
Eric
  #43
Old 03-07-2016, 09:29 PM
blueghoast's Avatar
Fun isn't it.
It's really not that bad once you get started, At least for me.
It looks intimindating untill ya get going on them.
GT.
  #44
Old 03-07-2016, 10:03 PM
Originally Posted by blueghoast View Post
Fun isn't it.
GT.
Your right, once the first tube was routed to and spot welded to the collector the rest fell into place.
Eric
  #45
Old 06-20-2016, 12:06 AM
New front tires should be here tomorrow. Still have to get a 5 point harness and install it. Need to make a battery hold down and fix the accelerator pump. Also need to fix the rust in the rear quarters.
ID:	431178   Click image for larger version
Eric
  #46
Old 07-05-2016, 08:58 PM
Took the car to Tri State Raceway in Earlville, Iowa last Saturday. First test run found the weak link in the 7.5 rear. Heated the tires, staged the car and loaded the converter to 2000 rpm, lights came down and nothing. I did break the beams as my friend told me I cut a 047 light. I was told by a track official that a u- joint broke but I didn't hear any thing banging around. Turned out the two small pinion gears let go in the rear. Time for a Ford 9".
ID:	432131   Click image for larger version
ID:	432132   Click image for larger version
Eric
