Old 03-22-2016, 03:46 AM
Best to take it off the car & then disassemble it. You can use your air to remove the cap & seals. Just use a blow gun at the inlet of the fluid & it will come off & out with a little bit of direct air pressure, just stand away from the ends because it will come out with so force depending on your air pressure.
