View Poll Results: Type of Camshaft in Your Street Pontiac
Flat-Tappet Hydraulic 166 49.11%
Flat-Tappet Solid 22 6.51%
Hydraulic Roller 106 31.36%
Solid Roller 44 13.02%
Voters: 338. You may not vote on this poll
Old 04-05-2016, 08:56 PM
archerytony's Avatar
archerytony archerytony is offline
Default Solid roller
Solid roller in my 468 and thinking solid ft in my other build 467 that I just started on
www.bowhanger.com
468 poncho powered 66 cutlass
77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html
  #62
Old 04-05-2016, 10:30 PM
Gtowolf Gtowolf is offline
Originally Posted by Gtowolf View Post
Comp 270 H #51-233-4 with 1.65 Harland sharp roller rockers
In a 68 R.A II 4 speed car
  #63
Old 05-26-2016, 10:30 PM
redhawk44's Avatar
redhawk44 redhawk44 is offline
In build stage as I write this. Hyd Roller 219/227 @ .515/.530 with 112 Lobe sep angle. Getting kind of excited to get it all together and get her back on the road.
  #64
Old 05-28-2016, 07:04 AM
pontibeast's Avatar
pontibeast pontibeast is offline
SD Performance stump puller with hybrid Crower Solid Rollers.
  #65
Old 07-09-2016, 03:43 PM
Old Tin Indian's Avatar
Old Tin Indian Old Tin Indian is offline
H-O Racing Specialties hydraulic camshaft HC-02 with Johnson Lifters.
Cast 16 heads w/dish pistons, 10.2:1 CR. Really strong street Cam.
my favorite place in the world
a nice smelly garage
  #66
Old 07-12-2016, 09:41 AM
Pontiac Derek Pontiac Derek is offline
Is that a 400?
A customer/friend of mine i just built a 408 for had that cam in his 9.00:1 400 with #16 D-ports, iron 4bbl, log manifolds, 2004R trans 2800 stall, 3.42 gears and it was a turd!
His was the HC-02D 232in 242ex .lift is high .400's 112lsa
I am asking because i am planning on putting it in a 10-1 467 with SD CNC 270cfm #17's ported iron intake, 900cfm Q-jet, i will be using 1.72' rockers with it, i figure its good for 470-500hp in the right setup.
If your engine is a 400 with 10.2:1 i can see that also working very well!
That 408 i built is now 9.5:1 with 230cfm #16's, summit 2801 installed at 109ilc
Its throttle response is night and day over his old setup!
Its all about the combo!
Thanks!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #67
Old 07-12-2016, 12:34 PM
this is a 455. as i remember some of the specs on this cam are
.465" intake lift, .469" exhaust lift. Duration @ .050"- 231* intake 242* exhaust. 113 1/2* LSA. also running 1 3/4" headers with full exhaust.
11" TCI converter w/turbo 400 and a 3.73:1 12 bolt.
Cast 16 heads with a cast iron 4 bbl intake, both gasket matched.
this car runs like nobody's business. it never misses a beat.
i've been running this combination for the past 28 years with no problems.
  #68
Old 07-12-2016, 01:13 PM
The specs i have for the HC-02D is-
301-313 advertised
232in 242ex
.470in .486ex
112LSA 108ILC
HO had another 02 cam iirc it was an 02A?
Do you have a cam card by chance?
Sorry for the hi jack i wont post anymore in here.
  #69
Old 07-12-2016, 01:36 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Ultradyne Solid Roller - .254/.262 @ .050, measured .670 lift and 110 ls.
Having a blast with it - supercharged!
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
The Following User Says Thank You to 69Goat1 For This Useful Post:
  #70
Old 07-12-2016, 02:15 PM
i do have a cam card somewhere. i'd have to really dig for it.
i bought and installed it in the mid-80's. i know it was made by
norris cams. i believe h-o racing specialties used different cam
companies to make their cams to their specs.
i know the former owner of the company is a member of this forum. maybe if this post is read by him, he could chime in about specifications.
i think there were 2 or 3 different hc-02 cams.
  #71
Old 07-12-2016, 03:26 PM
Can try here:
http://www.pontiacpower.org/PontiacCams.htm
Or here:
http://www.wallaceracing.com/cam-specs.htm
If there's still no satisfaction, I can break out the H-O catalogs.
  #72
Old 07-12-2016, 03:47 PM
just looked at a 1978 catalog.
more info in my post #67.
from the links above, i think there are probably way more
h-o specialties cams than we know about. i really don't know.
my cam came as hc-02. no a, b,c,d suffix.
the numbers i posted above are with 1.50:1 rockers.
  #73
Old 07-12-2016, 04:07 PM
I think I have 3 versions of the catalog, last one I think was like 88 or something. Maybe later I will dig them out, now I'm curious.
I ran H-O cams in the 80s in a number of engines/cars, think I tried a lot of available cams back then, H-Os were some of the ones I had success with. One summer I remember swapping cams like 6 or 7 weekends in a row. I had shelves of them, most were junk.
Lunati, Crane, and H-O were the ones I generally ended up sticking with.
Here's one of the Crane Hi-Intensity grinds that I liked to use with 400, as well as the next step up in the same line, would have to dig for that card.
  #74
Old 07-12-2016, 05:49 PM
richardk's Avatar
richardk richardk is offline
My HC-02 cam is:
301-313 Adv. dur.
231-243 @.050
113.5 LSA
I don't remember the lift numbers off the top of my head but I do recall HO called this their "744 hi-lift cam".
IIRC, Ken Crocie said there were several (4?) versions of this cam all with slightly different specs.
I bought this cam back in the late '80s and I'm still using it. (With Rhoads lifters.)
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
  #75
Old 12-31-2016, 03:03 PM
Now that this poll has had time to gather 296 votes it's interesting to note that nearly half of the votes are for the old tried-and-true hydraulic flat-tappet design that was original equipment in 99.999% of all Pontiac V8s.
The hydraulic roller is quickly gaining in popularity, but it is still outnumbered by a margin of 3 to 2 by the old-tech hydraulic flat-tappet.
  #76
Old 12-31-2016, 04:25 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
Comp Cams Magnum 292H, Rhodes lifters, 292/292, .501/.501
  #77
Old 12-31-2016, 04:41 PM
chuckies76ta's Avatar
That's only because of the cost and people don't want to spend $1000 for
Roller cams
  #78
Old 12-31-2016, 04:45 PM
Roller cams
Along with the added cost, for quite some time questionable reliability and noise issues were keeping a lot of us from pulling the trigger.
Only recently have the problems been solved with most of the hyd roller lifters available.
  #79
Old 12-31-2016, 05:45 PM
gassman_67's Avatar
next build,resto mod underway, hydraulic roller with EFI...but what cam? TH400, 3.36 gears...
  #80
Old 12-31-2016, 09:35 PM
sts sts is offline
f/thyd
