Old 04-05-2016, 10:40 PM
The reason you couldn't order a rear speaker with either the 8track or the stereo radio is that the price included front and rear speakers (2 front an two rear).
When you ordered a mono radio (either AM or AM/FM) without an 8 track it came with one front speaker only. Optional with these radios was a regular or echo style single rear speaker. The regular rear speaker option (Sepra-phonic) slid over the right tuning knob of the radio and the bezel controlled front to rear. The echo option (verbal-phonic) worked with a remote unit that was controlled by a switch of same design and location as the power top, rear defogger etc.
The only first generation Firebird available with a power antenna was 69 and it was mounted in the trunk. In 67-68 a manual rear antenna option was available but no power feature. Standard antennas for all three years were mounted on the front fender and were manually height adjustable.
Old 04-05-2016, 10:54 PM
Do you know of any aftermarket power antennas that will fit a 69 Firebird front fender? The boner antenna is a pain when it comes to a car cover.
Old 04-05-2016, 11:45 PM
I don't know about aftermarket but the original antenna screws on, if you leave it finger tight you can pull it to install the cover. If imagine there is plenty of room for a power unit.
Old 04-06-2016, 09:24 PM
So could you order a 4-speaker AM/FM multiplex with an 8 track in 69 that didn't require a switch? I'm told it was built into the 8 track?
Old 04-06-2016, 11:05 PM
There was never a separate switch with the four speaker system, it was controlled by either the balance bezel on the stereo radio or the same switch on the 8 track.
The switch number you mentioned is not a 69 part number, early 70's I'd say.
