Old 04-12-2016, 05:07 PM
77 Canamman's Avatar
Thumbs up SE Dash bezel restoration
I just recolored my dash bezel using a special gold tint lacquer finish, similar to the original finish used by PMD. My dash bezel, other than the gold being faded to silver, was otherwise almost perfect, so there was no need to have the machine turn redone.
I used Nikolas 2105 gold tint transparent lacquer, especially made for spraying onto metals, mainly instruments. First, I removed the plastic instrument bezels, wiper/washer emblem, and RTS emblem. Then, I cleaned the bezel with alcohol to remove dirt and contaminants. I sprayed several light coats until the desired gold color was achieved. The total cost was $32 shipped to my door, and 3 hours of my time. The lacquer dried in less than 30 minutes. I was very happy with the results.
ID:	426161   Click image for larger version
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-12-2016, 05:39 PM
Grand73Am Grand73Am is offline
Thumbs up
That looks fantastic! Thanks for the tip! I'm going to give it a try on one of mine.
Steve F.
Old 04-12-2016, 07:14 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Looks great! Thanks for the tip, I will give it a try. How many coats did you go with?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 04-12-2016, 07:37 PM
Thumbs up
I'd say at least 12 light coats, allowing each to flash.
Old 04-12-2016, 09:41 PM
muscle_collector's Avatar
looks great. thanks for telling us.
Old 04-12-2016, 10:58 PM
I think it is a great alternative for those of us with otherwise nice bezels that just need the color enhancement. For the rougher bezels, this will not be adequate since the lacquer does not cover up imperfections in the metal.
Old 04-13-2016, 11:25 AM
Poncho Dave Poncho Dave is offline
Very nice results. Thanks for the advice!
Old 04-14-2016, 01:15 PM
Compare the coloring to an original part:
Old 04-15-2016, 12:33 PM
Don 79 TA Don 79 TA is offline
WOW
that gives the inside a real nice pop to it
looks good
i had my standard bezel restored and man... what a difference it makes
Old 04-15-2016, 12:45 PM
I agree. Day/night difference.
Old 04-16-2016, 03:38 AM
Ric, the small piece you showed , is that what you started with & then after you sprayed it , it looked like the complete dash bezel, or did you have to do something to the small piece to make it look good???
Old 04-16-2016, 07:06 AM
The small piece is an image from the internet. It was used only to show the original unfaded gold coloring. I redid my entire bezel and the switch block off plate. I failed to photograph mine pre restoration. Mine had absolutely no scratches or corrosion, just the fading that is common with them.
