Old 05-04-2016, 07:44 PM
U47 U47 is offline
My complaint. 2 lane each direction. Speed limit 75mph. Approaching a large hill or mountain pass. There is five of you in the fast lane doing between 75-80. In front and in the rt. lane or slow lane are two semi tractor trailers or more starting to make the grade and they are two city blocks in front of you. They obviously knew you were fast approaching because they had to have looked to see if there was traffic so they could pass. One truck will pull into the fast lane knowing that their speed is going to be reduced because of the grade. The truck they are passing comes up even to them and then they sit side by side all the way over the summit and ever so slowly the passing truck overtakes the other and ever so slowly moves over. The driver knew these cars were coming at a high rate of speed but just had to do a bit of blocking. I have seen it so bad sometimes that these trucks will stay in the fast lane so long that cars start passing on the rt. side out of frustration. Sometimes the truck drivers will then try and pinch these cars passing on the rt.
Happens every day out there.
