Bart,are you going to the show this sat?I still have your dip stick and tube in my trunk!Tom
Is your builder in Nor Cal also, if you don't want to name the shop can you give the city.
I've heard of them. They do a LOT of the magazine project engine machine work. Excellent reputation.
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
Sounds like somebody is using aftermarket fasteners, but factory torque specs.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Around here the problem is finding someone who can grind a crank properly. Bearings don't live long if the journals have runout and rough finishes.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Shouldn't be that difficult. By run-out, I assume you mean taper?
Shouldn't be that difficult....? No, it shouldn't be, you're right. So why is it?
Runout /= taper Quote:
Good question, Will. People not taking the time to setup the grinder correctly, not dressing the stone enough times during the grinding process, coolant breaking down (i.e., ph level off, dirty filter, coolant concentration off), not using enough coolant flow while grinding, too fast cutting rate, too slow cutting rate and simply just not giving a damn. I'll give you an example: if I was grinding 15 6BT Cummings cranks, I would dress the stone after grinding 5. Half way through, I would shut down the stone drive and check the radius on the stone. Our RA spec on crank journals was 15 or less when it came off the grinder. After micropolishing, an RA of 5-7 was the requirement. If they're grinding crank journals oblong AND with too much taper(.0002 is max on a V8 crank journal), I would suggest "neutralizing"them to resolve the problem. That's just plain, old STUPIDITY...
There was one shop around here, about 30 miles South in Tacoma that I could trust and they went out of business a couple years ago.
I haven't built any engines since then so I really don't know where to go now. I've had several cranks screwed up by other shops. Got one 428 crank that looked like it had been polished with sandpaper and not one of the main journals was true to the crank centerline. I don't have a good way to measure stroke or index in my garage and I hate to think how bad that might have been off on that crank... Had to send it back out to get another .020" taken off it to true everything up (ended up .030" under and was turned .010" the first time). Strangely, didn't really have any issues with taper on that one. Had another crank come back where they didn't even touch the thrust face and it had pitting from corrosion. I pointed that out to the guy at the shop and he said "that's not a problem, it'll be fine." So, I took it to the shop that's now out of business and they laughed and fixed it for me. That was a Toyota 22R crank and the first shop hadn't even bothered to remove the screw-in plugs from the oil passages in the rod journals. Second shop said it was full of junk. I don't understand how shops that turn out crap work like that can stay in business.
We are lucky to have a few good crank grinders here in so cal.2 of them learned their trade from Joe Reath.Tom
Will try to come by your place sometime next month if I can work it out. Bart
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
No problem,not going anywhere.Tom
That marriage ended a few years ago. I rate Dougans as the best shop in SoCal, so you have to look elsewhere for the problem. 'Nuff said...
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Joe was a legend, Tom. My old friend, Bud, used to talk about Joe's skills in grinding Offy cranks. Like Bud said.."Always on stroke, always on spec"
Joe was a very dear friend,started doing biz with him when I was 17,his wife Deli is still with us and doing well.The brains behind the biz.Tom
#38
To catch up on the replies, all of which are greatly appreciated. The car has a 4 speed manual. When it went out at 940 miles, it didn't let loose it had a knock at the rear of the engine that was the thrust bearing. Oil pressure was good, gauges work fine. I have 3.23 gears and ran it in 3rd gear at about 3k rpm for a couple of miles on the freeway, but had taken it on the freeway already after this build. But, back to the thrust bearing and tranny. Maybe the shop that did the R and R of the motor didn't get it right, but could I have even gone 250 miles if it was amiss? I would have heard something. The builder is Joe's Engine Shop in Concord CA. Veteran builder, only takes motors, does not do R&R. Our 94 year old friend who owned a shop was Joe's mentor. He has done many many engines, including racing motors over the years. Very reputable. I'm pretty sure he did the motor himself the 2nd time (after the thrust bearing chatter). I know I need to break it in for 1k miles or so, but does that really mean not taking it over 2k for the first 1K miles? My buddy said no way I'd have to have been racing it plus had it overheat to have it come apart again. Just praying my block is ok, this car is original drive train Concours restored.
#39
The 'break-in' is usually for the rings seating in the bores.
Bearings don't need 'break-in'?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
#40
No you can go over 2000 rpm, that is non sense. Since you have a 4 speed that rules out the convertor pushing into the crank and killing the thrust bearing.
Now, when you have it balanced, the shop should have asked for your harmonic balancer, flywheel, clutch and pressure plate. If you run a heavy flywheel and it is not balanced it will hurt bearings. Was everything neutral balanced? |
