Old 06-06-2016, 10:35 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Thanks for making these, the boost guys will love the fact that lifting the heads a little won't be a new set of gaskets.
How far in the hole will the piston need to be?
Will there be other sizes or will this size work for a smaller bore?
Old 06-07-2016, 07:59 AM
Robert C.'s Avatar
Robert C. Robert C. is offline
Depends on rod type. Most steel rods use a .040 gasket. So .040 in the hole.
Aluminum Rods need more clearance from the head to piston top.
When ordering a IA II block with a 10.300 deck height there is no change in the distance of the wrist pin to the piston top. And if you need to cut the deck to 10.230 Stock height there is still no change when using a .040 gasket.
So it is a good sealing system for a dry deck motor.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 06-07-2016, 11:33 PM
Marty Palbykin Marty Palbykin is offline
The heads lift under boost so the rings needs to float somewhat.
That is key to how they function. ( more pressure more seal)
You can plumb a water block for street cooling if needed, although it was made for a race only application.
Old 06-08-2016, 03:26 PM
v869tr6's Avatar
Marty, did your factory block have water in it or did the alcohol do the cooling?
Wondering if I could plug all the holes in a factory block and even the E-heads and do some reverse cooling.
Old 06-08-2016, 04:00 PM
On my block we used both water and alcohol. ( we found the water was not necessary)
Yes we did that on Scott Schraders street car.
Old 06-08-2016, 05:46 PM
Just a thought, but IMO you could likely stay wet deck IF you countersink the block/head water holes slightly and use either rubber o rings or Right Stuff.
Water isnt very likely to get past Martys rings if you managed a water leak, and water pressure is unlikely to get high enough to blow out o-rings or Right Stuff. (I havent used water neck gaskets in years, just RTV. No issues.)
Old 06-08-2016, 08:03 PM
60man's Avatar
60man 60man is offline
I had the "Tiger Mod" done on my Tigers.
But I'm not boosted but run 14.8 CR.
Seems to be working.
Maybe next combo.
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 06-08-2016, 09:47 PM
v869tr6's Avatar
Thanks Bruce and Tom seems like a good idea, how far do the sealing rings stick up above the deck?
