#381
They say you have to use offset inlet/center outlet mufflers to make the Flowmaster tailpipes work.
#382
I just saw that..I must have had a old set..I know they fit well..
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#383
And By the way Ernie's motor has a max of 10.25:1 but im sure its acually 10.07:1 just needs to know how far down the pistons are in the hole!
He can see what it is whenever he freshens it up, Not bad for an engine that is not even zero decked lol!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
#384
It's the cold Canadian air I tell you. LOL!
#385
I love running in the fall when its cold..tricky to hook up but free horsepower!
#386
Yea in Houston that is about 1-2 weekends a year!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#387
TA MAN - did you get out last night?
#388
No but have done some backroad testing with the new carb body...hard to tell if there is a power increase...within a couple weeks be back at the track...
#389
So TA Man, you prove that the KRE 290 heads are providing good enough performance so that you may not have much to gain if at all by getting your heads ported to 305 or so.
#390
Odds are high it would run faster with a little more head.
#391
I had a good discussion last time at the dragstrip about headflow...Another fellow Pontiac racer insisted more head flow is always good...I disagreed it is not always better..all depends on the combination...
#392
Yep, look at original Ram Air V heads.
#393
Velocity is an extremely important consideration. Agree about balancing factors in the combination. |
#394
More cfm may not be beneficial if the cam is too small for the head flow.
#395
290's is enough for 10's, i went 11.50@117 in 4550 lbs... Ernie will do it!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
#396
What gear?
#397
I'm going to try and do it the hard way first!In decent air it would have went 11.1's..thats getting pretty close...and I've never expected to run 121/122...just the matter of getting to the track more..the 60's will come down a bit thinking 1.60's,still not leaving as clean and hard as it can.,testing this annular main body next..I have a small list of things to do this year..hopefully everything can get tested.
#398
Has anyone tested this combo with a well adjusted q-jet?
If so what intake? And, Ernie what size headers? |
#399
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#400
I have been running a Q Jet and a self ported RPM.
My best MPH is 122.3 with a 11:44 and spinning for 3-4 ft limited traction. Car has always ran flawless on the street and track. Have a T-2 and a Shaker(Jeff)) 455 4150 to bolt on very shortly. Im also trying to get the 60ft s down but im eager to see what the intake combo will do. |
