Old 06-30-2016, 04:20 PM
Garry Sr Garry Sr is offline
Originally Posted by TedRamAirII View Post
What is your ET/MPH/Weight/Gear now?
My 73 hasn't been to the track yet. The gear at present is a dog and doesn't work with my combo.
Old 06-30-2016, 06:34 PM
So what is the present gear? I'm just asking because 3.08 does'nt seem to slow a lot of these guys down! What is the Combo? Is it all a secret? ; )
A friend put 4.33 in his car from 3.73, it slowed down. Every car has its sweet spot.
Bill Nye.
Old 06-30-2016, 09:22 PM
ta man ta man is offline
Weather permitting hitting the track next Friday afternoon..its a track rental day for the next day's small tire shootout guys..and I'm going to join in on the rental.Will be running a new set of rear tires ET street pros..and my carb now has an annular main body.Should be a nice relaxed atmosphere to test...Torquewar is keen too so we can help each other..track prep is promised to be great!
Old 07-01-2016, 01:53 AM
Good luck man. Humble apologies for the intrusion.
Old 07-07-2016, 11:06 AM
Well weather not permitting!...Putting on new rear tires and street testing this new carb main body..and hitting a car show Saturday..
Old 07-07-2016, 11:47 AM
Steve C. Steve C. is offline
The HSD intake Skip borrowed from me is nice piece. I have two Holley Street Dominator intakes modified by Dave Bischopp. One uses my HP950 carb, the other has the carb flange modified for a 1050 Dominator carb. Both have port exit openings about 2.300" tall and use a SCE #128103 intake gasket that is about 2.320" tall. After the port work there is about 0.125" material above the ports for gasket seal.
The 'regular' HSD intake with my HP950 carb and a 1/2" open spacer made 589.4 hp at about 5700 rpm on the dyno, this was on a previous pump gas 4.210 stroke 462cid street engine. With the same engine & carb my Victor intake with 1/2" carb spacer made 600.9 hp at 6000 rpm.
As Skip mentioned his "high port" modified Torker II and my HSD intake dyno'd identical on his 550 HP pump gas motor.
Old information here:
Old 07-01-2016, 01:35 AM
It's not my thread.
