Hey guys educate me on KRE high ports? Would they be a good option for a 4" stroke street/strip motor? Can they use ARP bolts or must they use studs? Will they work with RPM intake or other Q-jet compatible intake? Can they use stock guideplates, typical roller rockers, etc? What does it cost to build a set with valves, springs, etc?
How much HP are you looking to make first off?
Those heads will not work with a out of the box rpm manifold and a 750 Q jet Carb will be a restriction in and of itself on a 428 or larger motor above 5400 rpm with theses heads dependant on how it's Camed. The flow level of the out of the box heads will overwhelm that rpm Intake manifold and even worse the limiting HP factor of that it will narrow up on the motors power band and make that band more peaky! A Victor or similar Intake is the only way to go, and to use such the car needs the gearing for it, and once your into the Victor manifold your Q jet can not be used . You did not post much info, but I think your looking to bolt on way too much head for the way your car is set up right now to make full use of it Also if you have D port headers now your into a real good chunk of money stepping into the needed round ports!
Chiphead, I believe they would be a great head for a 4" stroke street/strip motor. If one is using round port headers anyway, Highports are the most versatile head out there. If you order new from Kauffman you can get smaller intakes and exhaust valves in these heads for a smaller cube engine. I had them do a set with 2.075 intakes and 1.625 exhausts. They still flowed 317 and 202 @ .700 with good velocity in the port. These were bolted to a +0.30 389 cubic inch pump gas motor. I did use a victor on this combo, but the northwind intake is available now and more suited to these heads in stock form.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
I think they are a great head. Only drawback is the coolant crossover does not align with the timing chain cover. Plugging the coolant holes is the only cure.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Some of the SS racers still use a Qjet with a Victor. GTO Karl here used one on his street car and a Qjet had a nice adapter he made.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Hello all,I have a 4" stroke & 4.210 bore engine,do you think an original Nash intake will work ? Also what size valves would you order using a single pattern solid roller with 270 at .050 and .420 lobe lift. Thanks
If you want to use an RPM and Q-Jet maybe you should consider KRE d ports rather than the HP's
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
^^^ This
68 Firebird Are you running with the wind or breaking it? |
