Old 07-09-2016, 05:05 PM
gman005's Avatar
gman005 gman005 is offline
Default Distributor gear.
What would cause a gear to wear off half the teeth? It's a roller cam and it had a composite gear.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 07-09-2016, 05:56 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Which half wore off?
Go fast, see Elvis!
Old 07-09-2016, 07:22 PM
tom s tom s is offline
What oil pump,80lb pumps are gear killers.Tom
Old 07-09-2016, 08:50 PM
rompn63's Avatar
rompn63 rompn63 is offline
A new cam can do that.
Old 07-10-2016, 08:42 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
How old is the gear? Had it happen to mine last year
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 07-10-2016, 09:43 AM
I don't race, but I built several high performance engines for street cars over the years. H-O Specialties used to sell a set of galley plugs, and the one inside the block had a hole drilled into it to lubricate the distributor get.
I never was sure if that was needed or not for a street car. Does anyone still do that?
Old 07-10-2016, 09:46 AM
i82much's Avatar
i82much i82much is offline
Yes, this was something I specifically requested my shop to do when building my engine.
Old 07-10-2016, 10:28 AM
gman005's Avatar
The gear had some dyno pulls and about 10 runs on it. I have the oil hole at the gear. It's a 80lb pump from Butler.
71 Lemans Sport.
Old 07-10-2016, 10:32 AM
slowbird's Avatar
slowbird slowbird is offline
Get rid of the 80lb pump, use galley plug with small hole to oil gear (.040-.060), make sure there are no burrs/shape edges on cam gear and going racing.
Old 07-10-2016, 01:36 PM
firechickenman's Avatar
firechickenman firechickenman is offline
New cam? Did you check the gear on it for any sharp edges?
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 07-10-2016, 04:30 PM
Bill Eveland's Avatar
Did you break in the new cam with a bronze gear? It will soften the edges than put the composite gear back on.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 07-11-2016, 11:45 AM
gman005's Avatar
Yes it was a new cam. No I didn't break in the cam with a bronze gear. What's wrong with the oil pump?
71 Lemans Sport.
Old 07-11-2016, 12:09 PM
It takes a lot of power (stress) to turn a 80 psi pump. Maybe the gear isn't up to the task. Hook up a drill to the pump, spin it and you will see how much power it takes.
Bill Nye.
Old 07-11-2016, 01:19 PM
charlie66's Avatar
I have had a BOP gear for 7 years with a 80 psi pump with no problems...
My Half AN Injun.....
Old 07-11-2016, 03:48 PM
Old Goat Racer's Avatar
Why did u pull the dizzy?
Everybody knows somthin.
Nobody knows everything !
Old 07-11-2016, 03:50 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I had a composite gear fail once, but only after several years' service in one engine and then being moved to a new block and camshaft. We think it was the move that did it. It showed no sign of wear when we reused it, but definite signs of wear after the failure. I would suspect burrs on the the cam before suspecting the difficulty of turning an oil pump. Incidentally, we didn't use a bronze gear for break-in either time, though it certainly wouldn't hurt.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 07-11-2016, 03:54 PM
Charlie,go by a lottery ticket!
Old 07-11-2016, 03:59 PM
gman005's Avatar
We pulled it out because the motor died.
71 Lemans Sport.
Old 07-11-2016, 04:11 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Mine has well over 1000 runs, in two different short blocks, and 80 lb pump
Old 07-11-2016, 04:46 PM
BOP gear and 80 psi pump in mine too. Only about 1500 miles and about 100 passes and all is well.....so far.
Greg Weigart
