#101
Old 09-18-2015, 07:15 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Default Tiger Inserts
We are in the process of tooling up a run of deck inserts for the Tigers and also the E-heads. If anyone is considering this mod for the off season, please let me know as I've had to turn a couple of people away in the past based on product availability.
These are custom pieces made for this application and doing them in groups helps to keep costs at a minimum.
Thanks.
Calvin Hill
Hill Performance
708-250-7420
  #102
Old 12-17-2015, 07:06 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
Glenn did my heads and they came out nice. Will be updating when we get running.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
  #103
Old 07-10-2016, 05:42 PM
Jim Zeek's Avatar
Just got my motor back from the dyno. Its a 535. 13.86 - 1 compression. .050 Cometic head gasket. Made 954 hp and 776 tq. We made 8 pulls. Leak down results were 99 and 100 percent on center cylinders. #1 cyl was 97 and the rest were 98 to 100. Goint to try to make a few test runs before Norwalk then have at it at Norwalk and will be checking there and when we get back home.
  #104
Old 07-11-2016, 02:42 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Good power Jim!
  #105
Old 07-11-2016, 07:00 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Great to hear, I know it has been a long road. You must be a excited to do those test hits, your car is a beast. Enjoy it!
  #106
Old 07-11-2016, 08:54 AM
60man's Avatar
60man 60man is offline
Glen did my Tiger's several years ago. Haven't been out a lot but have about 80 passes and gaskets still good but haven't done a test in a while. I used to only get 50-60 passes before issues on my 535 @ 14.85 CR. It's a good investment in my opinion. 👍
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #107
Old 07-11-2016, 09:09 PM
gkinch's Avatar
gkinch gkinch is offline
I have a set that needs to be done before we build our motor!
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
  #108
Old 07-11-2016, 09:10 PM
gkinch's Avatar
we have the tiger heads
Gene Kinch
1999 Trans Am LS1
  #109
Old 07-11-2016, 09:38 PM
rompn63's Avatar
rompn63 rompn63 is offline
The insert is a good investment.
  #110
Old 07-11-2016, 10:02 PM
Jim Zeek's Avatar
send them to glenn
  #111
Old 07-12-2016, 07:39 AM
John Langer's Avatar
John Langer John Langer is offline
I put the inserts in my new heads to try to eliminate the extra weight of the external water pump system. Made 8 dyno pulls. Pulled the heads off and added the external water holes and pump system...
  #112
Old 07-12-2016, 07:45 AM
GTOGEORGE's Avatar
Can you guys run any head........or what's the rules?
GTO George
  #113
Old 07-12-2016, 08:22 AM
Cast heads. Stock port layout for Pontiac weight break. 5's weren't stock heads so they get whacked with weight similar to a bbc big chief.
  #114
Old 07-12-2016, 09:17 AM
mike leech's Avatar
mike leech mike leech is offline
Valve layout or port layout?
Sounds like you write the rules?
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #115
Old 07-12-2016, 10:49 AM
GTOGEORGE's Avatar
Thanks just wondering!
GTO George
  #116
Old 07-12-2016, 11:29 AM
The rules are written pretty clear. Port layout. So for a Pontiac eiieeiie.
  #117
Old 07-12-2016, 12:22 PM
mike leech's Avatar
So the cv is carrying weight too? Valves are ieeiieei ?
Let me guess.....you helped make sure that the v got weight
EHTTFMF!
  #118
Old 07-12-2016, 12:45 PM
I have zero input on any and all nmca rules.
  #119
Old 07-12-2016, 02:46 PM
mike leech's Avatar
Ok
EHTTFMF!
  #120
Old 07-12-2016, 09:13 PM
Are you saying the inserts didn't work?
I'm sure the water helps, but everyone that has used this mod showed a big gain in head gasket life.
Calvin Hill
Hill Performance
708-250-7420
