| Pontiac - Street No question too basic here! |
| View Poll Results: Type of Camshaft in Your Street Pontiac | |||
| Flat-Tappet Hydraulic |
166 | 49.11% |
| Flat-Tappet Solid |
22 | 6.51% |
| Hydraulic Roller |
106 | 31.36% |
| Solid Roller |
44 | 13.02% |
| Voters: 338. You may not vote on this poll | |||
#61
Solid roller in my 468 and thinking solid ft in my other build 467 that I just started on
468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
#62
In a 68 R.A II 4 speed car
#63
In build stage as I write this. Hyd Roller 219/227 @ .515/.530 with 112 Lobe sep angle. Getting kind of excited to get it all together and get her back on the road.
#64
SD Performance stump puller with hybrid Crower Solid Rollers.
#65
H-O Racing Specialties hydraulic camshaft HC-02 with Johnson Lifters.
Cast 16 heads w/dish pistons, 10.2:1 CR. Really strong street Cam.
my favorite place in the world a nice smelly garage
#66
Is that a 400?
A customer/friend of mine i just built a 408 for had that cam in his 9.00:1 400 with #16 D-ports, iron 4bbl, log manifolds, 2004R trans 2800 stall, 3.42 gears and it was a turd! His was the HC-02D 232in 242ex .lift is high .400's 112lsa I am asking because i am planning on putting it in a 10-1 467 with SD CNC 270cfm #17's ported iron intake, 900cfm Q-jet, i will be using 1.72' rockers with it, i figure its good for 470-500hp in the right setup. If your engine is a 400 with 10.2:1 i can see that also working very well! That 408 i built is now 9.5:1 with 230cfm #16's, summit 2801 installed at 109ilc Its throttle response is night and day over his old setup! Its all about the combo! Thanks!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
#67
this is a 455. as i remember some of the specs on this cam are
.465" intake lift, .469" exhaust lift. Duration @ .050"- 231* intake 242* exhaust. 113 1/2* LSA. also running 1 3/4" headers with full exhaust. 11" TCI converter w/turbo 400 and a 3.73:1 12 bolt. Cast 16 heads with a cast iron 4 bbl intake, both gasket matched. this car runs like nobody's business. it never misses a beat. i've been running this combination for the past 28 years with no problems.
#68
The specs i have for the HC-02D is-
301-313 advertised 232in 242ex .470in .486ex 112LSA 108ILC HO had another 02 cam iirc it was an 02A? Do you have a cam card by chance? Sorry for the hi jack i wont post anymore in here.
#69
Ultradyne Solid Roller - .254/.262 @ .050, measured .670 lift and 110 ls.
Having a blast with it - supercharged! ![]() Sent from my iPhone using Tapatalk
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads Faster on nitrous… |
| The Following User Says Thank You to 69Goat1 For This Useful Post: | ||
#70
i do have a cam card somewhere. i'd have to really dig for it.
i bought and installed it in the mid-80's. i know it was made by norris cams. i believe h-o racing specialties used different cam companies to make their cams to their specs. i know the former owner of the company is a member of this forum. maybe if this post is read by him, he could chime in about specifications. i think there were 2 or 3 different hc-02 cams.
#71
Can try here:
http://www.pontiacpower.org/PontiacCams.htm Or here: http://www.wallaceracing.com/cam-specs.htm If there's still no satisfaction, I can break out the H-O catalogs. .
#72
just looked at a 1978 catalog.
more info in my post #67. from the links above, i think there are probably way more h-o specialties cams than we know about. i really don't know. my cam came as hc-02. no a, b,c,d suffix. the numbers i posted above are with 1.50:1 rockers.
#73
I think I have 3 versions of the catalog, last one I think was like 88 or something. Maybe later I will dig them out, now I'm curious.
I ran H-O cams in the 80s in a number of engines/cars, think I tried a lot of available cams back then, H-Os were some of the ones I had success with. One summer I remember swapping cams like 6 or 7 weekends in a row. I had shelves of them, most were junk. Lunati, Crane, and H-O were the ones I generally ended up sticking with. Here's one of the Crane Hi-Intensity grinds that I liked to use with 400, as well as the next step up in the same line, would have to dig for that card. .
#74
My HC-02 cam is:
301-313 Adv. dur. 231-243 @.050 113.5 LSA I don't remember the lift numbers off the top of my head but I do recall HO called this their "744 hi-lift cam". IIRC, Ken Crocie said there were several (4?) versions of this cam all with slightly different specs. I bought this cam back in the late '80s and I'm still using it. (With Rhoads lifters.)
"I fishtail through the lanes, and I make my tires squeal. Power at my feet, and glory at the wheel. I wind the windows down, let the wind blow through my hair. God knows where I'm goin' to, but me... I don't care." Last edited by richardk; 07-12-2016 at 05:55 PM. |
#75
Now that this poll has had time to gather 296 votes it's interesting to note that nearly half of the votes are for the old tried-and-true hydraulic flat-tappet design that was original equipment in 99.999% of all Pontiac V8s.
The hydraulic roller is quickly gaining in popularity, but it is still outnumbered by a margin of 3 to 2 by the old-tech hydraulic flat-tappet.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
#76
Comp Cams Magnum 292H, Rhodes lifters, 292/292, .501/.501
#77
That's only because of the cost and people don't want to spend $1000 for
Roller cams |
#78
Only recently have the problems been solved with most of the hyd roller lifters available.
#79
next build,resto mod underway, hydraulic roller with EFI...but what cam? TH400, 3.36 gears...
#80
f/thyd
