Old 07-14-2016, 07:36 PM
blueghoast's Avatar
Originally Posted by ta man View Post
462 85 cc SD KRE 290 cfm heads,SD's "Old Faithful"HYD roller cam,1.65 Harland Sharpes,Torker 2 untouched,Wilson one inch four hole spacer,Holley 950 HP with 50 cc pump on front,Spectre 4 inch cowl air cleaner,30 degrees total timing,12 degrees intial,all in by 2800 rpm,Hooker 1 3/4 inch Super Comps.3 inch PYPES X,cone reducers into Walker 2.5 inch Ultraflows,2.5 inch tailpipes,10 inch 3200 Continental Convertor(over ten years in service now..four different 455 combos and two cars),th 350 ,3.08 rear gears
What size tire do you have on your car?
Thanks GT.
Old 07-14-2016, 08:12 PM
ta man ta man is offline
Thanks GT.
New set..275/60/15 Mickey Thompsom et pros...they are slightly larger than the old et streets in diameter and a slightly wider footprint...It looks like Saturday I will be testing the carb main body at the track to see how it works...Also Andy and Chris are going...both will rock the strip!
Old 07-14-2016, 09:36 PM
cnc's Avatar
cnc cnc is offline
Yep lookin forward to it first time out with drag radials ....need to learn on how to get the tires sticky....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-14-2016, 09:53 PM
Big burnout!If the tires don't collect everything on the return road they aren't hot enough!My best 60ft last time was the best burnout.....Andy's buddy Paul was running beside me!I'm hoping with the new tires I don't need to melt them to stick!
