Old 07-21-2016, 06:33 AM
cnc's Avatar
cnc cnc is offline
Originally Posted by Will View Post
You're definitely going fast enough. From what I've seen you'll actually MPH a little higher with wheel spin than when you hook up. I think it's because the spinning wheels act like a loose torque converter and allow the engine to stay in a higher RPM band until the car really gets moving.
I bet some simple changes will allow you to hook better. I was getting high 1.6x to low 1.7x 60' times on street tires and running high 12.60s to low 12.70s @ 106-107 MPH with all poly bushed stock suspension and Koni shocks.
For a burnout I smoked them as hard as I could. More heat helped. Dunno if it would be the same with DRs.
Yeah I saw. Few cars there with lower MPH than me with quicker times
Well from what I was told from a friend who watched my burnout said I didn't do it long enough .and perhaps I wasn't in the groove of the track quite right either ...so next time more burnout time......and maybe a better eye....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
