Al in all, the OP's issues sound like sloppy machining and too tight clearances. |
I'm on my 4th engine in my car. I built this one as these so called Pontiac expert shops and high end speed shop that did my previous two were junk. Had a local good machine shop do the machining and I did the spec checking and assembly. Nobody will take the time to do it right but the owner of the car! All of these shops just slap them together. The Pontiac expert's engine had a rod knock at startup, even though he supposedly dynoed the engine. He had to replace the crank and redo it. Even after that it leaked oil like a siv and burned oil. Local builder that does high end Chevy race cars built my 2nd short block. Rings never seated, burned oil like crazy. My current engine, rings seated immediately, not even a puff of oil smoke at startup. All of the clearances from the machine work were spot on. Took my time and checked everything before and during assembly. I will never let anyone assemble an engine for me ever again.
I have built 30 engines in my life. 6 have been Briggs 5 horse race engines, 2 small block Fords,13 Small block Chevy stock car engines a 250 inline Chevy engine and the rest Pontiac v8's. None of these engines had difficulty in ring sealing and none had rod bearing issues that were related to improper assembly. Oh, I had dropped valves, broken conecting rods and oil starved bearings (Oil pump belt came off)and an air filter stud getting swallowed up,but they all were checked and double checked. I wasn't doing it for a living so the time spent wasn't and issue. I crew chiefed a Late Model that the owner had the engine "professionally" built. It didn't last 2 hotlaps. So it's a crap shoot if you don't know how to do stuff. I feel your pain.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
73TA: I think it is great that you built your own engine and it runs great, is dry and all sealed up. It is a great feeling of satisfaction to do as much of the work on your hobby car as possible. I don't want people to feel however, that no shop in the country is capable of building a quality Pontiac engine or any engine for that matter. There are many talented machinists all over the country that really care about what they do and build great engines for their customers, Pontiac and others. The shop I work with builds every engine the same, period. Whether it's a Harley, a Pontiac, a comp. eliminator SBC that will run 13,000 RPM's or a 14 HP Kohler for a Cub Cadet restoration, all the work is done with the same precision. They have one way, the right way. Occasionally, the right way can get expensive as TIME must be spent to make everything as good as possible. Customers must understand, that's what it takes to get the desired results. By doing the final measurements and assembly yourself, you can save a ton of money and have that satisfaction. It takes me about 40 hours to properly measure, dress and assemble a V-8 engine. Someone has to pay for this or do it themselves. Not saying you tried to save any money with any of your builds, you may have just had shoddy work done. I always remind customers wanting to do a proper engine because it is so true; GOOD< CHEAP >FAST. Pick any two. There is no way anyone can have all three.
I asked on many Pontiac boards for recommendations for shop/machinists in N. Cal and never got one that didn't have as many good stories as bad. I think the art of machining and building engines has died with our generation, I'm 60. I assembled this engine out of frustration that I could not find anybody in central California that would do the job right! It did take many hours to assemble it and I don't have all of the measuring tools, but I got by, (palstiguage, micrometer, dial indicator, degree wheel). I had Dave at SD Performance cnc port the intake and Eheads and pick the cam. Turned out excellent. He estimates 550 Hp and it is smooth as silk. I can lug this engine in overdrive with no issues and it pulls strong all the way to 5,700! Used one of the BOP oil pan 1 piece rubber gaskets and 1 piece rear main seals along with the right stuff sealant on all the other gaskets. so far no leaks! |
Thanks for your reply and detail and I understand your frustration. Being in OH, we are blessed with many quality machine shops in state and in IN, TN and even MI are not that far away. In my post, I don't want to indicate we never have problems. We have many of them and do our best to overcome in each situation and send a customer home happy. Just last month we built a SBC solid roller 350 that was expected to make 600HP. First pull on the dyno it breaks a T@D shaft rocker arm in two at the trunion. Owner supplied the shaft system. He calls T@D and sends all the stuff back to them. They insist something is wrong with the build or the geometry or piston to valve clearance and refuse to do anything to remedy the situation. He ends up eating $1300.00 worth of T@D junk. We buy and install Crower stud mounted steel rockers and a stud girdle for half the price. It makes 606 HP @ 7400 RPM. We make 23 pulls, no issues. But the customer is still out the $1300.00. So he is "sort of" happy. A good shop will go the extra mile to try and resolve issues. In all honesty, a Pontiac is a simple engine to build as far as V-8 engines go. I wish you were closer to the midwest! Best of luck with your engine, and YOU built it. That's worth allot in my book.
