Old 08-03-2016, 06:56 PM
stobin's Avatar
stobin stobin is offline
Default Rear Coil Over Build
So one of the projects I was not able to afford to due in the past was upgrading the rear suspension to coil overs. Since I had the opportunity to make the improvements, I went forward with it. This was designed by one of the technicians at Cambra Speed. He designed an adjustable link system that will give me a choice of 3 positions for the height of the shock mounting, and 3 positions to set the angle of the shocks. Doug Norrdin at Global West recommended keeping the shock angles at no more than 15 degrees, so that was designed into the system. I purchased QA1 double adjustable shocks for the rear to match the front coil over set up. Spring rates in the front are 600 lbs., rears are 200 lbs. A rear crossmember was welded into the frame to mount the coil over system for added strength.
https://photos.google.com/photo/AF1Q...9cku-2pb5q_EKj
https://photos.google.com/photo/AF1Q...D1NWfs1ER1ZfRg
https://photos.google.com/photo/AF1Q...F5nHEOCydjEU5y
https://photos.google.com/photo/AF1Q...u4_4t8d1eNg24Q
https://photos.google.com/photo/AF1Q...fKVvz6FrdTup-2
https://photos.google.com/photo/AF1Q...AB8CE8vZnyJ6ZK
https://photos.google.com/photo/AF1Q...vqP_TQWGAYGQRw
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme.
Old 08-03-2016, 07:05 PM
stobin's Avatar
Default Drivetrain Upgrades. Magnum T-56 for the GA
So at the same time I was in the process of reworking the frame, I started to plan out the rest of the improvements I would like to make. I had installed a TKO 5-speed in the GA in 2008 which transformed the car. I decided that I would sell the 5-speed in order to afford a new Tremec T-56 six speed box. The majority of the upgrades I make to this car can only be performed by selling the parts I have in order to make it realistic to spend the money on the new components. I was able to sell the TKO for a very good price. The other way to afford these items is to work extra shifts. I am very fortunate to have a job that allows me to work extra shifts if needed. I work 12 hour shifts as a Registered Nurse, so when I need extra cash, I pick up extra shifts. The insurance settlement did help with the upgrades as well, but not as much as I decided I wanted to improve the car. The transmission crossmember needed to be remade. This one is much beefier than the one it replaces, especially after realizing the old one did have some flex in it. So as with the other frame upgrades, this piece is very overbuilt.
https://photos.google.com/photo/AF1Q...iijR94ylvaGX0r
https://photos.google.com/photo/AF1Q...aOaHfuqKD4m4da
https://photos.google.com/photo/AF1Q...kR3B25I2pI2J7w
https://photos.google.com/photo/AF1Q...HS-o-ZfFjSpqws
https://photos.google.com/photo/AF1Q...QoQoQsCI1rEmKg
https://photos.google.com/photo/AF1Q...x9LEtFEUge_lCX
Old 08-03-2016, 07:15 PM
stobin's Avatar
Okay, I'm done. I have had nothing but issues for months on these forums trying to post, so forget it. I refuse to waste anymore of my time.
