Motor oil is a coating, try running your engine without any and see if it makes a difference.
Car Craft Garage. Automotive Restoration |
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
I expected a stupid answer from GREATGTO but damn the motor oil thing was the stupidest thing ever.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Motor Oil is a Lubricant, Motor Oil is a Coolant, Motor Oil is a Hydraulic Fluid, but Motor Oil as a coating, while true (it does keep parts from rusting), is way down on the list of what it is used for in an engine. I will give you a D-Minus for that answer, not an F but darn close to it.
Thermal barrier coatings for combustion chambers: probably see a HP benefit with aluminum heads. Ping?
Friction reduction coatings; probably see a HP benefit in the rear gearset & transmission, maybe in the engine. Seems to mee that the high-loading surfaces are better-off with a polish and Redline lubrication. |
Agree, the anti-friction coatings must do something, because almost all the OE's use them on piston skirts. They do it for mileage and emissions. Coating allows tighter piston to wall clearance which means fewer hydrocarbon emissions. Anti-friction results in less heat and more HP. The real question which nobody can put a number on, including the coating manufacturers and sellers, is how much HP gain. Is it 2 HP on a 1000 HP engine?, 8 HP? They never want to put a real number on it. Certainly isn't anywhere near 50 HP or as I said, sanctioning bodies would be all over it. We run "hard anodized" pistons in our car. That could be considered a coating, I guess. We do it to provide a greater margin of error in our tuning. The soft aluminum piston is shielded from melting a fraction of a second longer with the coating than without. Think of it as the difference between a regular fuse and a "slow blow" fuse. So in a sense it makes more HP by remaining a piston longer than a glob of melted aluminum. Coatings have their place in an engine, but there are many more cost effective places to spend $$$ first.
You definitely can get coatings poor if you do everything.
Seeing sludge on windage trays and in oil pans even with regular oil changes I usually get mine teflon coated. Piston skirts since even Sealed Power coats them and piston tops. Usually bearings partly because mine sit for a couple of months before they get started and figure cold start it could help. It helps PolyDyn is local and I can drop stuff off and not have shipping costs. They do headers also now. But the new 455 for the 81 got no coatings but the pan.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Problem is pro stock re-Coats often I'm told. By a very reliable source.
Mike, hmmmm, if your ring-pinion is still swimming in 80-90W then please look into draining it ut, wiping everything clean, solvent spritz, then reload with the Redline stuff. Definite reduced temperatures. ....and reduced parasitic HP losses. |
What do you guys think of Swain's coatings for piston skirts to reduce piston to wall clearance?
Works great for that application.
I'm running Dewco lube. If I didn't know better I would think it was 10 W 30. Super light weight
I saw a commercial once where you could run slick 50 and drain the oil out of your motor with no damage....
The skirt coatings are there too reduce the effective piston to wall clearance while dealing with more bore distortion. It reduces noise without scuffing. That is it.
If you think about it, the friction in the power cylinder boils down to rings rubbing in the bore and the skirt to wall clearance shearing oil. Tightening the clearance up reduces oil film thickness increasing friction. Quote:
Check the Red Line stuff; likely thinner, likely slipperier, likely never get dark colored after many runs.
#38
Custom Lubes and Coatings have a place, putting them in the right places is sometimes a learning process.
#39
So I shouldn't be running 80w 90?
#40
Yes....otherwise you'd be too fast because you have E-heads.
